I am facing a puzzle – and unfortunately, so is our site manager. The basecoat plaster was applied last summer. It was quite hot at the time. At first, everything was fine. After a while, these whitish discolorations appeared. We pointed this out to the plasterer, who applied another coat. However, that only lasted a few days.
Now the questions are: Does anyone know what might be causing this? And what could be done about it? Should I consider hiring an independent building surveyor?
Unfortunately, I don’t know which plaster or paint was used, but I will ask the plasterer.
Do you have a photo of the same spot during the shell construction / before plastering? What type of masonry do you have? It looks like a liquid is seeping out through a gap (joint) and causing efflorescence on the surface.
Well, the foundation slab is actually supposed to be there.
borderpuschl27 Mar 2020 11:07It looks like the plaster is efflorescing, but the pattern does seem unusual. Is there no base sealing applied at all?
