ᐅ Primer for drywall
Created on: 16 Apr 2016 18:13
derLuki
derLuki
16 Apr 2016 18:13
I installed a suspended drywall ceiling in the basement (green gypsum board, the moisture-resistant type).
I have treated it with Murexin LF14 (diluted 1:1 with water) using a broad brush/primer brush in the first rooms. It felt like I applied more on the floor than on the ceiling 🙂. In the other rooms, I also applied Murexin LF14 (but diluted 1:2 with water) using a roller.
My question is, how many times should the drywall be treated with this, and how much coverage is needed? Is it enough if the boards appear shiny under a spotlight after application?
Should a heavier application be applied in the area where a sauna will be installed?
Thanks for your help!
blockhauspower16 Apr 2016 20:14
The primer is used to equalize the absorbency between the drywall and the filler and to act as a bonding agent. So if it looks shiny, that should be sufficient.
The sauna will surely be installed separately, so the absorbency of the drywall does not affect it.
Regards
