ᐅ Prefabricated house or solid construction – what is your opinion?
Created on: 7 Aug 2013 10:55
Leela
Hello!
We are currently exploring the topic of building a house, with plans to start next year. We are still very much at the beginning and have not yet decided whether to go with traditional solid construction or opt for a prefabricated house.
I’m interested in your personal opinions on this topic. What do you prefer, what are the advantages and disadvantages, and how did you make your decision?
Leela
Mauersegler
8 Aug 2013 08:44
Hmm... every homeowner has to decide that for themselves. Both options have pros and cons that need to be weighed individually, so making a general recommendation is difficult because what one person sees as a disadvantage, another might view as an advantage. Examples:
Pros of a solid (massive) house
Soundproofing and wind tightness
Balanced indoor climate
Flexible design options
Cons
Construction costs and time (including drying time)
Pros of a prefabricated house
Prior visit to a show home
Short construction time
Lower costs
Cons
Limitations in materials
Limitations in design
Air tightness
Dry indoor climate
I’m in favor of prefabricated houses... and would choose it again.
Der Da8 Aug 2013 09:38
Mauersegler schrieb:
Pros of a solid construction house
Sound insulation and airtightness
Sure, in our prefabricated house you can feel drafts easily. Sound insulation and airtightness are the same for prefab and solid construction houses if done correctly.
What is a balanced indoor climate, and why should it be different in a prefab house?
Fully customizable
Our prefab house was completely customizable. Nothing that money couldn’t fix.
Cons
Pros of a prefab house
Prior viewing of a show home
You can also visit a show home for a solid construction house.
Yes, short construction and assembly time, but the interior still needs to be finished and must dry just like in a solid house. You can usually move in 3 months after assembly. HOWEVER, waiting times for prefab houses are often longer. While solid houses start construction after about 6 months, prefab houses sometimes take 12 months before delivery at all. The only time advantage is that you don’t have to watch the shell construction process for long.
Lower costs
That’s nonsense. A good prefab house costs the same or even more than a solid house.
Cons
Material limitations
If the material quality is good, you don’t need a large choice.
Planning restrictions
Already mentioned, there are no restrictions. The only limitation is that you often can’t do any work on the exterior shell yourself, such as installing doors or windows.
Airtightness
Modern solid buildings are airtight as well. That’s why you almost always have to plan a mechanical ventilation system with heat recovery (MVHR), or otherwise open windows frequently.
In winter, this is actually a big advantage. The heat stays where it belongs... only the humidity needs to be managed.
Dry indoor climate
See airtightness
I’m in favor of prefab houses and would choose it again.
Written quickly in red above.
Solid build or prefab makes no difference if you compare the same quality level. It’s also a matter of personal preference.
At first, I was skeptical about a wooden house with panel walls. Today I know there’s nothing better than walls where you can just screw in a wood screw—no drilling, no dowels.
I’m 100% convinced by our prefab house. Even acquaintances who don’t immediately realize it’s a prefab house are surprised when they learn and see it.
Without mechanical ventilation with heat recovery, it wouldn’t work in this house, it’s simply too airtight.
For us, the decisive factor was fast assembly and spending little time on site, as we were also getting a child at the same time. Also, our gut feeling was 100% right. That’s actually the most important aspect. We also found it reassuring that the house was pre-assembled in a dry hall and already underwent quality control there.
DerBjoern
8 Aug 2013 10:36
I currently live in a prefabricated timber frame house from 1980. For my own build, I only considered solid construction. The current house is quite noisy between rooms and floors. Additionally, there are occasional dripping sounds in the walls coming from sewage pipes. These issues might not be as common today, but they discouraged me.
Musketier8 Aug 2013 11:25
Solid Construction and Coal.
Where a correlation between the two areas is excluded.
For us, the deciding factors were the limited budget and the discounts from banks on prefabricated houses.
Fairly speaking, I have to add that we never actually checked these two points, as the decision for solid construction was made quite early on.
Lilik
8 Aug 2013 16:15
Der Da schrieb:
While with a solid construction house the building often starts after just 6 months, with a prefabricated house you may have to wait 12 months before it is even delivered. The only time advantage is that you don’t have to watch the shell construction being built for long.
You can’t generalize like that. It depends on which company you are working with and how busy they are. For example, we signed the contract on April 4 and had exactly one month for the selections, because our house went into production in May. Earthworks began on June 18, and by July 10 our house was already standing, with the roof, windows, and front door installed. This week, the plumbing and heating installations will be finished. Our move is planned for December 1.
Regards
Lilik
Leela
8 Aug 2013 20:00
Very interesting, your opinions! Please share more.
I am genuinely interested in personal experiences and opinions, not recommendations.
