ᐅ Prefabricated House with Solid Construction – Which Building Company to Choose
Created on: 4 May 2017 17:39
Nicon1001
We are planning to purchase a prefabricated house built with solid construction. We do not have a plot of land yet. Our budget, excluding the land, is 200,000 € (about 220,000 USD). We have already looked at several houses online and read many reviews. This has made us more uncertain, since hardly any construction company gets good ratings on the internet. So far, we have found two companies that we really like, but unfortunately they only build in Lower Saxony or Northern Germany. Do you have any recommendations for companies in Rhineland-Palatinate?
Because we have relatives with strong craftsmanship skills, we are planning a so-called shell house to save some money and be able to customize it individually. Here is a rough outline of what we are looking for:
1.5 stories
about 140 m² (1,500 sq ft)
5-6 rooms
no basement
no garage
underfloor heating
ventilation system
We are aware that our budget is not very large, but we absolutely want to avoid poor workmanship. Therefore, we would appreciate any tips that could reduce costs or improve energy efficiency.
What are the must-haves (for example, wall materials, stairs, flooring, etc.)?
What can safely be chosen in the standard version?
We would be very grateful for any advice.
Thank you in advance!
Nicon1001
5 May 2017 15:34
Many thanks again to everyone who has offered advice and support. Perhaps a traditional solid construction house is the right choice for us after all. From the beginning, our options were limited because I didn’t expect to have the budget for a custom-designed solid construction house, so we had focused on a prefabricated house instead.
5 May 2017 15:37
Nicon1001 schrieb:
Hello ypg,
sorry for the confusion. As Nordlys already mentioned, I aim to hand over the house building project to a company and let them handle it. I understand that they usually subcontract to other companies (specialists), which doesn’t bother me at all. Ultimately, I want to avoid having to contact and commission every single party myself. I’d rather choose from a "portfolio" and say I want the house "Haftanstalt 2000" with the following special requests: XYZ
Regards,
Marco
A company that “lets loose” on the project is called a general contractor (GC), who usually offers turnkey construction services.
Turnkey can mean quite a lot of different things.
GCs are generally reluctant to subcontract trades because owner-performed work disrupts logistics (self-inflicted delays, poor planning conditions for the GC, lack of coordinated workflow).
Usually, painting and flooring, possibly minor electrical work, are the tasks you can or sometimes must do yourself.
Most people here in the forum build with a GC. Some still involve an architect.
Therefore, the full range of topics discussed in the forum is available to you—except that it mostly doesn’t cover building with a GC, which can be noticed quickly.
Best regards in brief
haydee
5 May 2017 15:42
Take a look around in your region. In our town, there is a company that provides the shell construction, including earthworks. They collaborate with a planner two streets away. This planner handles the building permit / planning permission, structural engineering, and construction supervision. They also work with other tradespeople.
Maybe there is something similar near you.
They are specifically tailored to homeowners like you. Unfortunately, they are too far away for you.
11ant5 May 2017 16:02
Nicon1001 schrieb:
Our options were limited from the very beginning because I didn’t expect to have the budget for a custom-designed solid construction house.
Actually, the opposite is true: "You sing the tune of the bread you eat" – the architect you hire directly is often more aligned with your budget than one employed by a house builder.
Almost every housing magazine shows annual examples where the best balance between living quality and cost savings was achieved by an independent architect.
Custom design with your own architect is not more expensive. What is (unnecessarily) expensive is a misguided custom design: for example, when you commission a run-of-the-mill "exclusive" design.
"Independent design" is usually necessary unless you have an ideal universal plot. So, in most cases.
And, as @Nordlys already says, savings come from critically evaluating extras like bay windows, corner windows, and the like – you don’t have to completely avoid these, just manage them wisely with your budget in mind.
Curly
5 May 2017 16:49
I could recommend our construction company "Weton Massivhaus," which is located near you. We are working with them for the second time now and have been very satisfied so far. You can design your house completely freely there, and you can choose between different finishing levels depending on how much you want to do yourself.
Sabine
11ant5 May 2017 17:57
Curly schrieb:
I could recommend our construction company "Weton Massivhaus," they are located near you.
That's right, I completely forgot about them earlier. They are in the Limburg area. If you might want to consider timber frame prefabricated builders as well: in the region, there is Fingerhut in Neunkhausen (roughly near Betzdorf).
