ᐅ Installing Ikea Metod Kitchen Units Precisely and Space-Efficiently on Sloped Ceilings
Created on: 29 Dec 2022 08:17
peopu
I am currently planning to install an IKEA Metod kitchen unit in a loft apartment with steep sloping ceilings. The challenge is to fit the kitchen as closely as possible to the angled walls to avoid wasting space, while also ensuring a safe and stable installation.
I am therefore interested in any experience or tips on precisely adapting the Metod carcasses to the sloping ceiling, especially how to best address uneven surfaces or angled corners using the available IKEA components. What methods or tools have you used to minimize cutting waste and loss of space? Are there particular combinations of wall cabinets, base cabinets, or custom modifications that work especially well for this?
Equally important for me is advice on how to achieve a secure wall mounting on sloped walls, since the standard IKEA installation instructions are usually designed for flat walls.
I appreciate any practical insights or ideas that can help with the precise and space-efficient installation of Metod kitchen units on sloped ceilings!
klo61
30 Dec 2022 07:52
Hello peopu,
Your question is very detailed, which makes it easier to give precise advice.
When it comes to saving space under a sloped roof, based on my experience as a kitchen installer, make sure to measure everything carefully in several places, including the height at different points and the maximum depth you can use. Sloped ceilings are often irregular, so this is important.
Another tip: Use filler panels to neatly cover any gaps. For example, a panel cut at an angle and fitted to the cabinet wall. These panels can be easily adjusted with a fine saw or jigsaw.
For wall mounting: Make sure the screws are long enough (at least 6-8 cm (2.5-3 inches)) and are screwed into a solid building panel or beam. If no beams are available, you can also create a substructure on the wall using wooden battens.
Hope this helps you!
peopu
30 Dec 2022 09:38
Thanks in advance for the detailed advice!
faso31 schrieb:
Here I would work directly with precise angle measuring tools, such as digital angle finders or bevel gauges.
That sounds reasonable, I have a digital angle finder and will use it to double-check.
daalessio schrieb:
Regarding wall mounting: Roof slopes often have less load-bearing plaster or drywall. I would definitely look for the wooden frame structure behind and fasten there with suitable anchors and screws.
Exactly, I have wooden beams behind the drywall, so I will mount the fixtures there.
I am still unclear on how to optimize the approach for very steep slopes, around 45 degrees or more, especially since the upper cabinet then has very little support surface. How have you solved this? One of the wall cabinets should remain semi-circular, but adapting it to the slope is challenging.
Dopoki
30 Dec 2022 11:11
For clarification:
peopu schrieb:
I am still unsure how to optimize the approach for very steep slopes, around 45 degrees or more, especially since the upper cabinet then has very little support surface.
A proven solution here is to install a stable support or a specialized bracket under the cabinet to help bear the load. Alternatively, interior panels with solid wood joints can be precisely fitted underneath the cabinet to provide firm support.
More specifically: Instead of securing the upper cabinets only with hanging rails, a wooden profile is also fixed to the slope, on which the cabinet rests. This prevents unnecessary strain on the wall fixings.
For semi-circular cabinets, adjustments can be made by modifying the back panel or underside, if possible using thin strips as support braces. Custom-made units often use MDF cuttings for this purpose.
blapau
30 Dec 2022 12:39
One additional note regarding the appearance:
An important consideration for cabinets near sloped ceilings is air circulation. Especially in attic rooms with high radiant heat, the distance to the roof should not be too tight. Slightly recessed panels create a small air gap, which helps to protect against moisture and preserves materials in the long term.
peopu schrieb:
One of the upper cabinets is supposed to remain semi-circular, but fitting it to the slope is problematic.
Semi-circular models can often only be combined with custom-made side or roof panels. Patience during trimming helps here, often involving some sanding work that pays off.
Z
zarHenning
31 Dec 2022 07:14
For angled cabinets: use brackets and shortenings. Screw into wooden structures; panels can be cut to fit. For half-round cabinets, adjusting the side panels helps; a back panel is often not necessary.
peopu
1 Jan 2023 10:22
Update on my installation:
I have now carefully measured and roughly positioned the cabinets. The sturdy wooden battens used as additional supports on the sloped ceiling actually help a lot.
Dopoki schrieb:
Instead of attaching the upper cabinets only with hanging rails, a wooden profile is also fixed to the slope, which the cabinet rests on.
This really provides more stability. The curved cabinets were indeed easier to install with trimmed side panels, resulting in a tight fit without gaps.
Thanks to everyone for the many valuable tips and constructive suggestions!
I would appreciate it if more practical experiences come up, especially regarding space-saving solutions with IKEA Metod cabinets under sloped ceilings.
