ᐅ Pouring a Concrete Wall as a Retaining Wall – Will It Withstand the Pressure?
Created on: 3 Jul 2018 00:49
moni1512
moni1512
3 Jul 2018 00:49
Hi, my plot is located on a slope, so my terrace is lower than the ground behind it. I would now like to support this with gabions and fill the rest since I still have the excavated soil in my garden. This will raise my plot higher than my neighbor’s on the left side. I would like to build a small retaining wall along the boundary, sloping from 0 to about 1.5 m (5 feet) over a length of 12 m (39 feet). This way, my plot would be level at that point. A friend recently suggested digging a trench and then using formwork to pour a concrete wall. Now my question is: will that hold?
Evolith
3 Jul 2018 07:58
If you do them properly, yes. Anchors deep enough, reinforcement, and so on. We faced the same problem.
Don’t underestimate the huge amount of work involved and also the costs.
Steven
3 Jul 2018 08:32
Hello Moni
That will hold!
Dig a trench about 80cm (31 inches) deep. Then build a formwork above ground that ends where you want the top edge of the retaining wall to be. Pour concrete into it. Use a mix ratio of 1:4. Then insert reinforcing steel bars. Don’t skimp on that. It will hold.
Oh yes, the wall should be about 25-30cm (10-12 inches) thick.
The costs are not particularly high if you do everything yourself.
Steven
HilfeHilfe
4 Jul 2018 19:12
Pulled 20 meters (66 feet). Hollow blocks, inserted steel rods, and concrete. However, they were at most 1.20 meters (4 feet) high.
fragg
5 Jul 2018 08:13
HilfeHilfe schrieb:
Pulled 20 meters (65 feet). Hollow blocks, steel rods inside, and concrete. But they were a maximum of 1.20 m (4 feet) high
What kind of foundation? And was it backfilled with soil at the rear? Is it possible to compact the soil behind?
HilfeHilfe
5 Jul 2018 08:19
fragg schrieb:
What kind of foundation? And backfilled with soil at the back? Can the soil behind be compacted?
The foundation wasn’t too complicated!
It’s 30 cm (12 inches) deep, with 20 cm (8 inches) of gravel and concrete, then the first stone on top (10 cm (4 inches) in the soil, 10 cm (4 inches) above).
Yes, soil on top of that.
