ᐅ Window opening options with controlled residential ventilation – planning ideas
Created on: 1 Nov 2020 14:22
pagoni2020
After deciding to install a controlled residential ventilation system, my mindset regarding the possibility of opening windows has perhaps changed. I would appreciate hearing about your experiences on this topic.
We plan to design the larger glass areas in the so-called open space with a 1/3 to 2/3 ratio, meaning each would have one hinged door (no tilt-and-turn function); the large window by the dining table would even be fixed glass, while the individual rooms would have at least part of the window as an opening casement.
Originally, I wanted everything to be fully openable, at least to be able to bring in larger items if needed, and especially to ventilate at 150% capacity since I am a fresh air enthusiast. However, with controlled ventilation, fresh air is already supplied throughout the house, so I would essentially just have to change my mindset that used to tell me to open all the windows wide.
This way, I could install significantly more fixed glass, for example in the loft area where I had actually planned an automatic opening for ventilation.
Somehow, I still feel that I should be able to open everything, but that seems to be just a feeling rather than a real necessity.
For example, in the bathroom or even more so in the kitchen, I could install a very wide strip of uninterrupted glass—but then I wouldn’t be able to open the window.
What am I overlooking in my considerations, or what suggestions do you have on this topic?
pagoni2020
5 Nov 2020 17:36
haydee schrieb:
Whether it’s a garage or carport doesn’t really matter, but a fixed window element positioned in the wrong place always does. I think you can only partially predict how and what you will use beforehand. You only realize that in reality.
True... because you, or in my case I, always have to adapt to new situations that you couldn’t fully foresee before. However, the basics can be planned, and we will figure those out.
If there actually turns out to be a completely wrong decision on this topic, it can be changed afterwards. If...
We are very meticulous about many details and make sure everything suits our needs, so we put a lot of thought into it and also leave ourselves enough time.
But we will probably have a few “mistakes” here and there as well.
