ᐅ Poroton T9 unfilled or Poroton T8 with mineral wool insulation?
Created on: 23 Feb 2015 16:02
fridolinmeier
Hello, my project will start this summer and I need to choose a masonry block now. The options are Poroton T9 unfilled and T8 filled with mineral wool (additional cost 2500 €). My question is (I have done some research already): Are the unfilled blocks really much more prone to cracking than the filled ones? I have looked at them, and the webs are definitely much thicker. The mineral wool is packed very tightly, so I hope it will only shrink a little over the years.
Thank you for your help.
Fridel
annab377
10 Feb 2020 20:57
Do you know the U-value of both types of bricks? Obviously, the additional cost of 5000 (including currency) takes several years to pay off purely through heating cost savings, depending on the type of heating system and the development of energy/electricity prices.
However, the more massive the house, the longer it stays warm in autumn and cool in early summer because of its thermal mass. It also reduces external noise more effectively. Additionally, with more solid masonry, there is more material left in the outer wall for installing water pipes or other utilities (which can then be better soundproofed, etc.).
Of course, it ultimately depends on whether these relatively small benefits are worth the additional 5000.
Snowy36
10 Feb 2020 22:14
I have the 42 mm (1.7 inches) unfilled and, as of today, would choose the filled 36 mm (1.4 inches) for acoustic reasons.
nordbayer
11 Feb 2020 08:13
Snowy36 schrieb:
I have the 42 cm (16.5 inches) non-filled blocks, but as of today, for soundproofing reasons, I would choose filled 36 cm (14 inch) blocks.
How close to a busy street do you live for that to make a noticeable difference for you?
Selbstbau
11 Feb 2020 10:22
annab377 schrieb:
Isn't the unfilled one the U8?
What wall thickness do you want to use @Annika90
**Edit: I’m interested in a 49cm (19 inches) brick thickness.
I checked on the Schlagmann website, for example:
  • T7 with a U-value of 0.14 (unit price according to Schlagmann about 8.5 EUR)
  • T8 with a U-value of 0.16 (unit price according to Schlagmann about 8 EUR)
  • U8 with a U-value of 0.16 (unit price according to Schlagmann about 13.3 EUR)
The T7 and T8 are filled with perlite. The U8 is the one with many small chambers, which are supposed to break relatively easily during shell construction (see picture).
I don’t understand the pricing at all. The perlite-filled bricks, which are supposed to be more stable, clearly cost less than the air-filled one? Who wouldn’t choose the perlite brick (whether T7 or T8) then??
Image from schlagmann(.)de
Hey,
we have the U8 42.5cm (17 inches).
You can forget the prices listed by Schlagmann.
Go to your building materials supplier and ask for a quote (of course, calculate square meters or quantity beforehand).
For us, the brick cost about 3.50.
annab377
11 Feb 2020 11:12
Have you already started / did you have any issues with the fragility of the U8?
Selbstbau
11 Feb 2020 11:26
We built in 2017/2018. During the masonry work, we didn’t have any problems with the whole blocks. However, the cut blocks were quite fragile. Around 20 blocks broke in our hands, which I still consider acceptable. Chasing or milling grooves for electrical wiring also went quite smoothly... always with care and common sense.
