ᐅ Poroton bricks in the foundation wall are damaged.
Created on: 14 Oct 2019 23:27
buzzi_cement
is it necessary to replace these damaged bricks?
Close-up of four sand-colored stone blocks with many pores and a joint in the middle.
Close-up of an orange-brown brick wall with a vertical crack in the joint in the center.
Close-up of orange bricks with vertical grooves and gray mortar residue.
Close-up of light orange bricks with many pores; blue paint splatters on the joint.
Close-up of orange-brown bricks with visible joint crack and mortar marks.
Close-up of orange bricks with many pores, lined up side by side.
Close-up of a brown brick wall with a central vertical crack.
Fummelbrett!
15 Oct 2019 11:14
I do not see any damaged bricks.
Lumpi_LE
15 Oct 2019 11:23
Making fun of the uninformed ultimately leads, through three detours, to the current election results.
Tamstar
15 Oct 2019 11:30
@Lumpi_LE This is the second thread with the same question. Everyone already reassured him in the first request, so it is no longer being taken seriously now.
Silent010
15 Oct 2019 11:35
@buzzi_cement It’s good that you are involved with the house during the construction phase and not relying entirely on the contractors. From my experience, I can tell you that this is the right and important approach.
From both a thermal insulation and structural perspective, cracks in the bricks and damages of this size are completely harmless.
If you find larger openings through which you can see through, ask the contractor to fill these gaps with two-component foam (for thermal insulation purposes).
nordanney
15 Oct 2019 11:36
Construction work is different from, for example, watchmaking.
So—this time without irony—please don’t worry. These bricks are neither defective nor will anything happen to your house. You might even encounter things that make you gasp or cringe. But on construction sites, people working are usually what feels like “rough manual workers,” who, in cooperation with different trades, ultimately produce exactly what you ordered: a house.
Lumpi_LE
15 Oct 2019 12:00
Tamstar schrieb:
@Lumpi_LE This is the second thread with the same question. Everyone already reassured him on the first request, so now it’s no longer being taken seriously.
That's true... that is indeed a bit odd..
