ᐅ Cartridge Pool Filter or Sand Filter System?
Created on: 24 Jun 2019 09:07
Malz1902
Malz1902
24 Jun 2019 09:07
I couldn't find a thread on this topic. I'm sure some of you have a pool, whether it’s a Quick Up, frame, steel wall, or even a permanent one. What kind of filter do you use? At the moment, we are still using a simple cartridge filter. However, I am considering switching to a sand filter. Can you recommend anything? What have your experiences been like? We only have a relatively small frame pool, 305x76cm (10x2.5 ft).
rick201824 Jun 2019 12:40
It's not just about the pool size, but also about the pump and the filter you need. Your current pump probably isn't sufficient for a "proper filter." Do you have a wastewater connection to perform backwashing?
Malz1902
24 Jun 2019 14:00
The pump that came with the pool does not have one.
rick201824 Jun 2019 14:17
The pump requires the appropriate pressure and volume for the specific filter. That’s why I suggested that you will probably need to replace it as well.
The filter is backwashed (depending on the level of contamination). This usually goes directly into the sewer or you have a large infiltration system. 1-2 m³ (35-70 cubic feet) are lost each time...
