ᐅ When are Pergolux point foundations load-bearing?
Created on: 27 Feb 2024 14:46
Coletrickle_7808
I have installed six pier foundations in several stages underneath our terrace. Two pergolas from Pergolux will be set up here.
The foundations measure 40x40 cm (16x16 inches) or 50x40 cm (20x16 inches) and are each about 50 cm (20 inches) deep. Below them is a gravel layer approximately 30 cm (12 inches) thick.
The oldest foundation is about 8 days old, the newest one 4 days.
In recent days, the temperature has been around 10°C (50°F), sometimes up to 14°C (57°F), but at night it has dropped to around 5°C (41°F).
When can I start assembling the Pergolux and secure it to the foundations? The attachment will be done using stainless steel (V4A) concrete screws. Each Pergolux weighs about 200 kg (440 lbs) fully assembled. The larger foundations each support both pergolas placed side by side.
Thank you very much.
Bausteinefeckt
27 Sep 2024 04:26
Thank you very much! The Pergolux S2 weighs 200kg (440 pounds)! Therefore, I would need to add approximately 189kg (417 pounds) of ballast to the pergola, and then it should work.
Tolentino27 Sep 2024 08:49
Or attach it to the exterior wall of the house instead. That might work out well overall.
Simon-189
27 Sep 2024 10:28
Bausteinefeckt schrieb:
Thank you very much! The Pergolux S2 weighs 200kg (440 lbs)! Therefore, I would need to additionally weigh down the pergola with about 189kg (417 lbs), and then it should work.
Before you do that, I strongly recommend checking with the manufacturer to confirm whether you are allowed to add extra weight to the structure like that.
