ᐅ Combination of landing stairs: straight stair with landing and half-turn staircase
Created on: 10 Jun 2025 22:25
Bauherr8899
Bauherr8899
10 Jun 2025 22:25
I found a staircase design that I find interesting, combining elements of a landing staircase and a half-turn staircase.
What dimensions would this staircase have from a top-down view, assuming it is square and does not have one side with fewer steps than the other as shown in the picture? What tread depths and riser heights would you expect? (Single-family house, 2.5 m (8 ft) ceiling height) This is more of a calculation example, but unfortunately, I don’t know how to work it out.
What are your general thoughts on this staircase?
Thank you.
Wooden spiral staircase with light brown steps, white balustrades, top view.
10 Jun 2025 23:32
This appears to me as a simple demonstration of a very basic double-winder staircase using a poor tool.
I don’t see a landing. Winder treads become wider on the outside because they rotate around a central point. In this respect, the steps are not landings, even if the tool suggests otherwise.
Stair treads should not be visually striking, but rather safe to use. There are standard or minimum dimensions for this, for example 19/26: 19cm (7.5 inches) riser height to 26cm (10 inches) tread depth.
hanghaus2023
11 Jun 2025 10:13
Insufficient information.
Floor-to-ceiling height? (Ceiling height alone is not enough)
Stair width?
Is it compliant with DIN standards?
Should there be a railing between the steps?
Bauherr8899 schrieb:
What do you generally think about the staircase?
I wouldn’t recommend it; the tread depth is wider in the middle of the staircase than elsewhere. It would be better to split the landing only in the middle.
Do you have a plan showing where the staircase is supposed to go?
11ant11 Jun 2025 11:11
In general, I would say, "this looks like a design flaw."
nordanney
11 Jun 2025 11:29
What are your general thoughts on the staircase?
Not attractive and also rather impractical.
hanghaus2023
11 Jun 2025 13:22
Is your planner really any better than your DIY?
