ᐅ Sloped Site: Initial Floor Plan Idea & Request for Feedback
Created on: 18 Mar 2021 22:01
GaertM1
we have now started the first "internal" draft planning and I would be very grateful for any feedback – especially if there are any of our “ideas” that are completely off the mark...
Development Plan / Restrictions:
"Facts"
no development plan, last plot at the edge of a village area
Plot size: 330m² (approx. 21.8m x 14.8m / 71.5ft x 48.5ft)
Slope: about 7°
Clay-loam soil, limestone at shallow depth
Information according to building permit inquiry
Site coverage ratio: 0.6
Floor area ratio: 1.2
Street = building line
2 parking spaces
Number of storeys: max. 2 full storeys
Roof style: any
Eaves height 6m (20ft)
Ridge height 10m (33ft)
Client requirements
Style, roof type, building type: flat roof preferred, but e.g., also “modern barn” style
Basement with daylight from the slope as a lower ground floor, above that a “real” storey
2 persons (35, 36 years old)
Space requirement ground floor and upper floor: approx. 200m² (2,150 sq ft) total
Office: 2x home offices
Guest stays per year: none
Open architecture
Modern construction method
Open kitchen with kitchen island: yes
Number of dining seats: 4
Fireplace: no
Garage, carport: not essential, 2 parking spaces sufficient
Utility garden, greenhouse: as little garden as possible
Other wishes: KNX system, air conditioning for main rooms
Designer: do-it-yourself
What do you like most? Why?: main living areas all on one level
What do you dislike? Why?: bathroom and dressing room borderline “small”
Personal budget for the house, including fixtures: approx. 500,000 to max. 700,000 euros
Preferred heating system: we don’t really care
If you had to cut back, on which details or extensions
- Can be omitted: lounge on ground floor, pantry
- Cannot be omitted: guest WC on upper floor, dressing room, minimum clear ceiling height on upper floor 2.70m (better 3m / 9ft 10in)
Why has the design turned out as it is now?, for example:
“Optimizing” the eaves height while maximizing the use of setback distances
Minimize earthworks as much as possible (considering the soil...)
Have I completely misjudged any fundamental aspect? Is any detail of the design “absurdly expensive”?
Note 1: Views are just for a general idea of the plot situation at this stage – windows and so on still look pretty rough…
Note 2: Plan is drawn roughly to scale (5mm grid = 50cm / 20 inches), numbers in () are m²; north is bottom left on ground floor and upper floor plans, the beautiful view to the south is top right :-)
Already now: many thanks for all your feedback!!!
Modern two-story 3D house model with large window fronts on green area.
Modern white cube villa on raised base with carport ramp and garden
Floor plan of a building section with wine cellar, technical room, office, hallway, lounge, WC; terrace and parking spaces.
Hand-drawn floor plan of an apartment with living, cooking, dining, sleeping, bathroom, corridor.
Technical drawing on graph paper: cross-section of a building with upper and ground floor, length 2150.
Satellite image with orange, red-bordered plot on cadastral map.
GaertM1
19 Mar 2021 21:30
Flat roof vs. Modern Barn was naturally meant as "or." I also find split-level interesting. Roof style is more of a secondary priority; for example, I also like a mono-pitched roof—just no dormers, bay windows, or similar features. I will probably only tell the architect which architectural styles we like (New Objectivity, Bauhaus, Modernism, International Style); the roof shape can then develop from that.
The 200m² (2,150 sq ft) is of course not set in stone. With a clever layout, we could certainly manage with a bit less. But: we currently have a 110m² (1,185 sq ft) condominium, and that doesn’t include the stairwell, technical rooms, or basement. Overall, it definitely needs to be somewhat larger. We certainly don’t want a "hobbit house" ;-)
rick201819 Mar 2021 21:33
200m2 (2,150 sq ft) is fine for two people.
Of course, it can be smaller, but if you like having space, why not. We are also just two and have more than 200m2 (2,150 sq ft).
haydee
19 Mar 2021 22:07
@hampshire has well under 200 sqm (well under 2,150 sq ft) and it feels very spacious. However, there are fewer rooms.
Make sure to include in your room plan the issues that bother you now, for example, the distance between the wall and the bed being too small. Then set a minimum distance there.
19 Mar 2021 22:28
Size is nice and all, but with a 330m² (3550 sq ft) plot, you should consider that when looking out the window, you might quickly end up just looking into the neighbor’s garden instead of enjoying your own property.
11ant20 Mar 2021 00:32
GaertM1 schrieb:
which architectural styles we find appealing (New Objectivity, Bauhaus, New Building, International Style)
I would mildly question whether it is necessary to demonstrate on the village street in Knieritz at the Knatter what is taught as the latest trend at ETH Zurich. Avant-garde belongs only to a limited extent in rural areas.
rick2018 schrieb:
200 m² (2,150 sq ft) for two people is okay.
However, a final result of 200 m² (2,150 sq ft) is quite different from a rough target of 200 m² (2,150 sq ft).
haydee
20 Mar 2021 05:49
Even in a small rural village, an unconventional house is allowed. Avant-garde architecture is not just for big cities.
