ᐅ Sloped Site: Initial Floor Plan Idea & Request for Feedback
Created on: 18 Mar 2021 22:01
GaertM1
we have now started the first "internal" draft planning and I would be very grateful for any feedback – especially if there are any of our “ideas” that are completely off the mark...
Development Plan / Restrictions:
"Facts"
no development plan, last plot at the edge of a village area
Plot size: 330m² (approx. 21.8m x 14.8m / 71.5ft x 48.5ft)
Slope: about 7°
Clay-loam soil, limestone at shallow depth
Information according to building permit inquiry
Site coverage ratio: 0.6
Floor area ratio: 1.2
Street = building line
2 parking spaces
Number of storeys: max. 2 full storeys
Roof style: any
Eaves height 6m (20ft)
Ridge height 10m (33ft)
Client requirements
Style, roof type, building type: flat roof preferred, but e.g., also “modern barn” style
Basement with daylight from the slope as a lower ground floor, above that a “real” storey
2 persons (35, 36 years old)
Space requirement ground floor and upper floor: approx. 200m² (2,150 sq ft) total
Office: 2x home offices
Guest stays per year: none
Open architecture
Modern construction method
Open kitchen with kitchen island: yes
Number of dining seats: 4
Fireplace: no
Garage, carport: not essential, 2 parking spaces sufficient
Utility garden, greenhouse: as little garden as possible
Other wishes: KNX system, air conditioning for main rooms
Designer: do-it-yourself
What do you like most? Why?: main living areas all on one level
What do you dislike? Why?: bathroom and dressing room borderline “small”
Personal budget for the house, including fixtures: approx. 500,000 to max. 700,000 euros
Preferred heating system: we don’t really care
If you had to cut back, on which details or extensions
- Can be omitted: lounge on ground floor, pantry
- Cannot be omitted: guest WC on upper floor, dressing room, minimum clear ceiling height on upper floor 2.70m (better 3m / 9ft 10in)
Why has the design turned out as it is now?, for example:
“Optimizing” the eaves height while maximizing the use of setback distances
Minimize earthworks as much as possible (considering the soil...)
Have I completely misjudged any fundamental aspect? Is any detail of the design “absurdly expensive”?
Note 1: Views are just for a general idea of the plot situation at this stage – windows and so on still look pretty rough…
Note 2: Plan is drawn roughly to scale (5mm grid = 50cm / 20 inches), numbers in () are m²; north is bottom left on ground floor and upper floor plans, the beautiful view to the south is top right :-)
Already now: many thanks for all your feedback!!!
Modern two-story 3D house model with large window fronts on green area.
Modern white cube villa on raised base with carport ramp and garden
Floor plan of a building section with wine cellar, technical room, office, hallway, lounge, WC; terrace and parking spaces.
Hand-drawn floor plan of an apartment with living, cooking, dining, sleeping, bathroom, corridor.
Technical drawing on graph paper: cross-section of a building with upper and ground floor, length 2150.
Satellite image with orange, red-bordered plot on cadastral map.
hampshire
21 Mar 2021 10:40
But not every architectural style is suitable as a living space.
A residential building that isn’t suitable as a living space cannot be considered good architecture. Impossible.
With a 500,000–700,000 limit for the desired 200 sqm (2,150 sq ft), I also don’t see architecture but rather functional living.
Good architecture doesn’t have to be expensive. Often seen, for example, in the wonderful series "Grand Designs." There are frequently very affordable yet excellent architectural solutions for real-life challenges. Of course, you can’t replicate this exactly in Germany, but it’s definitely worth watching.
GaertM1 schrieb:
We’re not fixed on one style—as already mentioned, it doesn’t have to be a flat roof; a modern barn with a mansard roof also has its appeal ;-)
It’s good if you like several styles, we felt the same way. Much more important is that the person designing the house gains a clear understanding of you and your lifestyle. That is the foundation for creating something unique that succeeds rather than simply failing. This goes far beyond just functional requirements. Starting with drawings is nice but, especially at the beginning, just a side aspect. Unfortunately, many architects don’t make the effort to guide their clients in this way, or they no longer try because they often encounter misunderstanding and rejection.
Look for someone who enjoys this creative process and be open to surprises. The result will fit you and your surroundings. The budget is sufficient for this.
askforafriend29 Mar 2021 20:35
Is there an update?
23 Dec 2023 09:35
GaertM1 schrieb:
Thanks for the tip about the architects – with Spiekermann, I immediately like three designs (cube, split-level, and the cube with the brick facade). We’re not set on any one thing – as mentioned before, it doesn’t have to be a flat roof, a modern barn with a mansard roof also has its appeal ;-)
Is there a new plan in the village after more than two years?
hanghaus2023
23 Dec 2023 10:27
I would also be interested to see what the architects have made of it.
