ᐅ PLATSA from IKEA: How do I safely assemble large wardrobes?
Created on: 24 Aug 2015 13:27
Aneas
Aneas
24 Aug 2015 13:27
I recently purchased the Platsa wardrobe from IKEA because I was looking for a large, flexible storage system for my bedroom. Now I am facing the challenge of assembling the wardrobe safely and securely, especially since it consists of several modules combined to form a large unit. My detailed question to the community is:
How do you assemble large PLATSA wardrobes from IKEA in a way that ensures they stand stable, don’t wobble, or tip over, particularly when working with multiple elements? Are there specific techniques or tips to consider during assembly, for example regarding the order of assembly, wall mounting, or alignment of the modules? And which tools or aids are especially useful for this?
I want to avoid the wardrobe becoming unstable or causing damage later on, so I would appreciate any detailed feedback, especially from experienced users who have assembled larger PLATSA systems or those who have paid particular attention to safety and stability.
Thank you in advance!
fidasi
24 Aug 2015 15:43
Hello Aneas,
Your question is very well formulated, and these kinds of details you mention are important for large PLATSA systems. I assembled a 3-module wardrobe system just last month and am happy to provide you with a detailed step-by-step guide that helps make the construction stable and secure:
- First, be sure to read the IKEA assembly instructions carefully, even if they sometimes seem “standard.”
- Assemble the individual modules completely and separately first, meaning the frames, shelves, back panels, and doors should be installed before sliding them together.
- When connecting the modules, make sure to properly and tightly fasten the connecting fittings (usually shown in the instructions as metal parts). The screw connections play a major role in stability.
- It is also important to always secure the wardrobe to the wall. IKEA usually provides appropriate mounting kits for this purpose. Wall anchors are crucial to prevent the furniture from tipping over.
- Use a spirit level during assembly to ensure all modules stand straight. Especially with larger setups, even a millimeter of misalignment can cause problems later.
- If there are uneven floors, small leveling wedges or adjustable furniture feet help prevent the system from wobbling.
- Tools: A cordless screwdriver is very helpful, allowing you to tighten screws precisely and firmly. Also, a spirit level and a drill are necessary if you need to make holes for wall mounting.
One last tip: allocate enough time and, if needed, get help carrying and aligning the modules, since larger wardrobes can be heavy and cumbersome.
If you like, I can also explain in more detail how I solved the connection between the modules. My wardrobe is already standing at about 2m (6.5 ft) height.
If you have more details about your wall or floor condition, please let me know, as that can also have an impact.
Tause
24 Aug 2015 18:12
fidasi schrieb:
One last tip: Allow enough time and, if necessary, get help when carrying and aligning, especially since larger cabinets are heavy and cumbersome.
I agree with this, but I would also like to add a word of caution: you shouldn’t rely solely on the assembly instructions. Especially with a modular system like PLATSA, the connections between the individual modules can be weak points under load. Therefore, I recommend checking after assembly whether the connections can withstand tensile and shear forces.
Interestingly, wall mounting is crucial for preventing tipping, but if the wall is thin or made of less sturdy material, the IKEA wall fasteners often aren’t sufficient. In such cases, you should check whether additional reinforcement or different types of anchors are necessary.
fidasi schrieb:
When connecting, make sure to properly and securely fasten the connecting fittings (usually shown as metal parts in the instructions).
I agree—the quality and especially the strength of the screws are critical here. Sometimes, using larger or specialized screws can yield better results.
I’m also curious if anyone has experience with alternative connection methods, such as special brackets or metal connectors that IKEA doesn’t provide.
Finally, the load distribution should also be considered—where will which area be particularly stressed? Does the placement of the adjustable shelves still suit your intended use?
What exactly have you planned for your PLATSA? How large will the overall cabinet be?
KINMIN4
25 Aug 2015 09:08
Aneas schrieb:
How do I safely assemble large PLATSA wardrobes from IKEA so that they stand stable, don’t wobble or tip over, especially when working with multiple units? Are there specific techniques or tips to consider during assembly, such as the order of assembly, wall fixings, or module alignment?
In short: Assemble the units individually, securely connect them using the included connectors, fasten all units to the wall, use a spirit level, and check their stability. Tools needed: cordless drill/driver, spirit level, drill for wall anchors.
That’s all you need. The rest is patience and carefulness.
