ᐅ Plastic L-shaped Blocks – Experiences
Created on: 29 Apr 2019 10:05
trendyandi
trendyandi
29 Apr 2019 10:05
Since I need to retain the ground towards the neighbor in the garden (about 50 cm (20 inches)), I came across plastic L-shaped retaining blocks while searching for suitable ones. Although these are more expensive than the concrete version, they are significantly lighter at around 30 kg (about 66 lbs) for a height of 55 cm (22 inches), which makes handling easier in terms of weight.
My question is: does anyone have experience with these “blocks”? Are they easy to work with, or is there no substitute for concrete L-blocks?
Greetings from the Swabian region!
Domski
29 Apr 2019 11:18
I would have concerns about the durability of plastic (UV, water, etc.).
lastdrop29 Apr 2019 11:30
You don’t bury plastic in the garden ...
Nordlys
29 Apr 2019 12:58
That will be WPC, which should actually be durable. I just don’t see a real advantage compared to concrete.
trendyandi
29 Apr 2019 13:08
Hmm, well, half the weight is definitely a strong argument, especially if you don't have an excavator in your personal equipment fleet...
According to the product description, it is made of recycled plastic...
Dari9887
10 Apr 2020 11:15
Hi, have you already installed the plastic L-shaped blocks yourself, or did someone else here do it?
