ᐅ Plastic feet breaking off on KALLAX – any alternatives?
Created on: 5 Oct 2024 08:34
Joachim33
Joachim33
5 Oct 2024 08:34
I have a small but annoying problem with my KALLAX shelf from IKEA. The plastic feet keep breaking, usually after a few moves and light use at the latest, at least one foot is damaged. This is not only frustrating but also affects the stability of the shelf. Does anyone here know the causes of this recurring issue? Are there any proven alternatives to the original plastic feet, perhaps made of metal or wood, that last longer and don’t damage the shelf? I am looking for recommendations that are easy to install and do not leave marks on the floor. Thanks in advance for your helpful tips!
blapau
5 Oct 2024 10:02
The well-known issue with KALLAX plastic feet usually stems from the brittle material quality, which becomes fragile and cracks over time due to stress and UV exposure. A good alternative is furniture legs made of metal or wood, which are often available at home improvement stores as replacements. It is important that the replacement feet have the exact same type of attachment to avoid damaging the shelf.
One recommendation: metal legs with felt pads can also protect the floor and are much more durable. However, before purchasing, you should check the attachment holes on the KALLAX, as the shelf has a relatively thin-walled design. It may be necessary to reinforce stability with suitable anchors or small metal plates.
If you have some DIY skills, you can also use sturdier wood as a leg, securely fastened with screws that match the color. This actually protects the plastic frame better than pressed-on plastic feet.
Jensson
5 Oct 2024 12:27
Here is a brief guide for anyone experiencing issues with broken plastic feet on the KALLAX shelf and looking for a durable alternative:
1. Identify the type of foot: The KALLAX typically has feet with standardized screw threads. Remove the feet and measure the diameter and thread pitch.
2. Find replacement material: Metal feet made of aluminum or stainless steel are durable and often available in various lengths and thicknesses. For floor protection, integrated felt pads are recommended.
3. Check the attachment: If the foot is screwed in, make sure the screw is not too long to avoid damaging the shelf. The shelf is made of thin MDF with a laminated surface.
4. Installation: Completely remove the old plastic feet. Carefully clean or reinsert the threaded insert if necessary. Screw the metal feet on firmly but not too tight.
Common mistakes to avoid:
- Over-tightening can cause cracks in the cabinet.
- Feet that are too short or without protection can leave scratches on the floor.
Summary: Metal feet with felt pads are the best alternative if careful attention is paid to precise attachment.
Domau0
5 Oct 2024 16:45
I would like to add some technical details to the thread by Joachim33 that many might not be aware of.
The plastic feet on KALLAX are actually designed for light loads and occasional repositioning. The material is a brittle hard plastic that develops microcracks after repeated mechanical stress—especially from edge impacts or tipping—that quickly propagate. Due to IKEA’s design, the attachment is screwed into a thin particleboard carcass, which itself offers limited stability.
This means, conversely, that a replacement foot needs to be not only sturdy but also relieve stress on the mounting system. Some users have had good experiences with so-called screw-in metal feet that attach to a metal threaded insert in the carcass. These screw-in inserts can potentially be retrofitted with a special repair kit if the plastic threads are stripped.
When attaching, you should definitely avoid using screws that are too thin, as they can damage the wood. Another option is to use threaded inserts that are glued into the carcass—this provides better load distribution.
My question for you, Joachim33: How often do you relocate the shelf, and how heavy is the load? Do you use the shelf depth as a seating area or similar? These factors are important to recommend the appropriate solution.
gregto
6 Oct 2024 07:50
Domau0 schrieb:
How often do you move the shelf, or how heavy is the load?
I would like to add to this point, as I recommend different solutions depending on the intended use.
If the shelf is rarely moved and the load is normal (for example, as a typical bookcase or storage shelf), better replacement feet made of metal with soft glides are often sufficient. This protects the floor and significantly extends the lifespan.
For furniture that is moved frequently or must support heavier loads (such as a bench, worktable, or under substantial weight), I would recommend sturdy wooden feet with metal brackets that are securely screwed to the frame. Although this option requires more effort to install, it offers considerably greater stability.
In any case, caution is advised when modifying the furniture to avoid weakening the frame through screw holes or excessive stress. A tip: use washers to prevent pressure marks.
In general, I strongly recommend carefully measuring the correct type of feet beforehand and selecting feet with low height and a wide base area whenever possible.
