ᐅ Plastering or drywall?
Created on: 3 Jan 2009 12:47
Lily
Lily
3 Jan 2009 12:47
I have a wall in my basement that I would like to cover. At the moment, the masonry is visible. Would it be better to plaster it, or is it easier to install drywall panels? Which option requires less work and costs less?
Dassins
4 Jan 2009 12:33
I believe that plastering takes more time, but I still plastered my basement because it looks neat and well-finished.
Lily
5 Jan 2009 07:12
plastering requires more effort initially, but it’s worth it because it looks much nicer. Also, the room becomes smaller if you install a drywall partition, since you first need to build a substructure with battens. Plastering is messier but results in a better appearance.
Lily
5 Jan 2009 07:37
A plastered wall simply looks better, and it’s not as difficult as it might seem. Sure, it creates more mess, but in the end, it looks nicer than a drywall (plasterboard) wall. Also, it’s harder to hang anything on drywall because you always need special anchors.
Lily
5 Jan 2009 07:49
even a drywall (gypsum board) wall requires work and creates mess, because the battens underneath need to be fixed to the wall first. Additionally, gaps form between the panels, which you have to fill with joint compound. If this is not done properly, it will always be visible. I would also prefer plastering in that case!
Peanuts74
9 Dec 2015 14:03
There are also adhesives or something called setting plaster, I believe, which you can use to firmly attach the boards. Drywall is probably easier, but plastering looks nicer...
