ᐅ Plastering greasy clinker bricks on the chimney
Created on: 5 Dec 2007 09:40
duke-skate
duke-skate
5 Dec 2007 09:40
I have a clinker brick fireplace at home, but it already looks quite dirty. Can I simply plaster it with chimney plaster, or do I need to consider anything else?
hans0n
5 Dec 2007 09:48
Please provide more details first on whether the fireplace is open or closed. 🙄
linus
5 Dec 2007 11:22
So if it is open, definitely cover the heat-exposed areas with fire-resistant material; otherwise, find out which plaster is resistant to extreme temperature changes.
hans0n
5 Dec 2007 19:24
Clean the bricks thoroughly and definitely use a bonding primer. I believe gypsum plaster is well suited for these temperature fluctuations.
duke-skate
5 Dec 2007 19:26
Sorry for the late reply, I just got home from work. It is an open fireplace. Thanks for the quick responses.
Best regards, Duke!
harald-porge
9 Dec 2007 11:46
There is stove plaster available that can be used directly, with a quartz-based primer underneath. It should then hold properly. After a few days, heat it up thoroughly and check if it holds. Otherwise, get back in touch here.
