ᐅ Plaster and paint are peeling off after painting.
Created on: 27 Mar 2019 12:59
jessi7755
Help!
I hope you can give me some advice.
We carefully renovated the ceilings and walls of our old building. That means we removed damaged areas of the old plaster, repaired them with Rotband, then applied Ardex 828 and sanded it down. We repeated these last two steps several times until the surface was completely smooth. In some rooms, new drywall ceilings were installed. Where there were only small imperfections, we just smoothed them with Ardex.
After filling, everything was primed with a deep primer and left to dry.
When painting, the gypsum stuck to the roller.
In other rooms, we first applied crack primer and then paint. After two days, small cracks appeared extensively, and in some areas, the paint peeled off in pieces about the size of a 5-cent coin. This happened mainly in the corners but also on the flat surface.
What could be causing this? The walls were fully filled and primed. Also, everything was allowed to dry thoroughly for a long time.
Do you have any tips?
By the way, the materials were bought from a specialist paint retailer at a high cost.
Nordlys
28 Mar 2019 20:30
Something is wrong here. Gypsum plaster that is 14 days old is not fully dried, but it is dry enough that dispersion paint does not dissolve it. Also, a primer was applied beforehand. Where is the application error? K..
guckuck2
28 Mar 2019 22:50
Primer applied before Rotband?
According to the technical data sheet, 14 days are generally just sufficient on average.
