ᐅ Planning a Detached Single-Family Home With or Without Ventilation
Created on: 4 Jan 2016 08:57
mathschut
The construction of my single-family house is set to start in March. Now I have a question. The architect says that a central ventilation system is too expensive and suggests just opening the windows sometimes. My carpool partner used to work as a heating engineer and insists it definitely should be installed in a new build. What do you think, should I install ventilation or skip it? A friend told me that if I do install ventilation, I should have the intake ducts laid under the floor slab right away. What are your thoughts on that?
U
Username_wahl4 Jan 2016 18:56We are installing a decentralized ventilation system, a fresh air heat exchanger by Marley. The costs are reasonable.
DragonyxXL6 Jan 2016 09:59mathschut schrieb:
Would you place the air intake under the slab foundation? The idea is to preheat the air during the coldest winter by drawing it inside through a pipe labyrinth. I can’t say how much that helps. If you use a mechanical ventilation system with heat recovery, the intake does not need to be located under the slab foundation.
