In about three weeks, we are supposed to finalize our electrical planning on site. Unfortunately, our electrician is somewhat old-fashioned, which makes it difficult for me to collaboratively plan a future-proof electrical setup with him. Therefore, I am currently educating myself to ensure that the networking in our single-family home is fundamentally future-proof.
Basically, it’s about the LAN network... LAN wall outlets are relatively expensive, so proper planning is even more important.
About us:
- Mid to late 20s – couple without children. Planning for 2 children in the near future.
- Single-family house with a usable basement, 2 full floors, and fully equipped with concrete ceilings
- Utility room in the basement with air-to-water heat pump, ventilation system, photovoltaic system
- The router is planned to be located in the office on the ground floor
- The upper floor includes bathroom / bedroom / 2 children’s rooms
- No satellite dish or cable TV — we will use Internet TV exclusively!
Now, I am struggling to network our single-family home sensibly but as cost-effectively as possible.
I have the following questions:
1. Slightly off-topic: In the living room, I would like to have an in-wall conduit installed on the TV wall (the TV will be wall-mounted) so that no cables are visible. Is this sensible and affordable? I will get exact prices from my electrician if this makes sense at all. Would it also make sense to install power outlets at TV height? How do you plan the connections on your media wall reasonably? What should be considered?
Since we plan to use a Magenta TV box and thus IP-TV, a total of four LAN ports in the living room area would presumably be useful, right?
2. How many LAN outlets and especially where should LAN outlets be installed? Mainly: which cable? Is CAT6 sufficient?
→ Such a double LAN outlet certainly costs close to €200, so planning must be really sensible.
Is it really necessary to install 2 double LAN outlets in each children’s room? I always wonder: what is actually going to be plugged in there?
One port for the TV and one port for a multimedia device should be enough, right? So four connections would probably be overkill, correct?
The fact is: It will certainly take years or decades before our children actually use these outlets... Who knows what changes might happen by then? Therefore, could we not cost-effectively use empty conduits (empty pipes) instead?
Is it also possible to “branch off” from an existing double outlet afterward to add more ports for the room? What should be considered here? Or should we consider having an empty conduit prepared in another spot in the room so that a socket can be installed later?
3. How do you solve the “router problem”? Should the one router be placed in the office (ground floor) with LAN outlets in the existing bedrooms upstairs to ensure a stable LAN connection? Or is a router upstairs absolutely necessary?
4. How important are LAN outlets in the utility room? Should the router possibly even be located in the utility room? Because of the concrete ceiling between basement and ground floor, a second router would almost certainly be needed. How should this situation be handled with a basement?
5. What do you think about installing empty conduits for CAT cables in the kitchen / hallway etc. to enable later retrofitting? Is this relatively affordable in new builds?
I would appreciate any feedback so we can make the best possible plans 🙂
About us:
majuhenema schrieb:
We are currently working on our electrical and network planning. Apart from some self-research here and online, I don't have much knowledge on the subject. I followed the rule of thumb: one network outlet in the bedrooms and home offices, and two by the TV in the living room.Forget rules of thumb – you know:1. Your hopefully realistically furnished future floor plan
2. Your current circumstances.
Count exactly how many users you have in these two scenarios – in 2., separately count those who currently rely on multiple extension cords. If in any room the actual number is below the rule of thumb, then exceptionally use the latter.
MBPassion2 Jan 2022 13:16majuhenema schrieb:
I would really appreciate it if you could take a look at our floor plan and give me some feedback. It definitely makes sense to carefully plan the wiring, since you rarely get another chance to install cables later on. 🙂 It’s also best if you know the furniture layout in advance. Personally, in rooms where computers will be used, I would rather install two simple LAN outlets in different locations (e.g., opposite sides) instead of a double outlet, since the needs in the room might change.
Regarding double outlets in general (e.g., for the TV area): in principle, they don’t cost significantly more and can certainly be done. However, I wouldn’t overemphasize their importance. On one hand, you either have just one device or several more (e.g., TV, AV receiver, set-top box, game console, etc.). On the other hand, you can always install a small switch right where you need more devices. And finally, if you have very good Wi-Fi coverage, that is usually sufficient. For example, Unifi offers In-Wall HDs that provide a wall-mounted Wi-Fi access point plus two outgoing LAN ports simultaneously.
If I had to plan the access points in your place, I would probably position them on the ceilings in these locations. The upper floor with the three rooms in a row seems to be the most challenging. You could have an outlet installed in the ceiling of the bedroom. If you don’t need an access point there, you can simply cover it with a blank cover plate. In the basement, you could alternatively put the access point directly in the office (near the door) on the ceiling.
AMNE3IA schrieb:
I would position the access points exactly as @MBPassion has already indicated.You have a nice profile picture – do you live there, is it edited, or is the street really that clean?https://www.instagram.com/11antgmxde/
AMNE3IA schrieb:
The street was recently paved.Congratulations! In my experience, dirt and litter usually appear within hours at most...https://www.instagram.com/11antgmxde/
