ᐅ Planning an Automatic Irrigation System
Created on: 1 Aug 2021 00:14
Crossy
Due to bad weather, we didn’t make as much progress on the landscaping as planned, but now we are moving forward and are currently planning the automatic irrigation system.
We have tried several planners for this, and the one from DVS worked best for us. However, some aspects are still unclear, so I hope to get some feedback on our plan and clarify a few open questions.
Here is our current plan:
Grundriss mit Beleuchtungskegeln und Lichtzonen über dem Hausgrundriss
Legend:
Orange: house, terrace at the house, paved areas in front of the house
Green: lawn
White areas: paths/stairs/terrace
1: raised garden beds
2: hedges
3: trampoline (in-ground)
4: terrace
5a-c: potential water faucets (a: outside, b: roof terrace on garage, c: inside the garage)
General information:
Currently, we have planned the entire supply through faucet 5a. More on this below in the questions.
The plot slopes about 7m (23 ft) from top to bottom towards the street.
Especially in the upper bottom left area, there are zones with less-than-optimal irrigation. This area is not used much, and perfect irrigation would be too expensive due to the many angles and "obstacles" (trampoline, terrace).
The following questions came up during the planning:
1. Multiple water sources: I assume that if I want to use multiple water sources, I will need to purchase as many irrigation controllers, valve manifolds, etc., as there are sources, correct?
2. Considering the slope: Do I need to take the slope into account during the planning? I couldn’t enter this in the planner. I imagine it might affect the pressure, so irrigation zones going uphill should have fewer sprinklers planned accordingly.
3. Quality levels of components: For many parts, you can choose between Eco, Expert, and Premium. These usually have a significant impact on price, but I don’t see a clear benefit from the descriptions.
Currently, we plan to use Expert quality for the irrigation controller and valve manifold, and Eco for the rest.
Is the upgrade to better materials worth the extra cost (for example, the installation unit for Hunter MP Rotators is about €12 (about $13); with 21 rotators that’s roughly €250 (about $275))?
4. Drip irrigation: Neither the manual nor the planner showed how much water demand to calculate per square meter, so I’m unsure if one connection is enough for a raised bed or hedge, or if several should be planned.
Related to this: Does each raised bed need a separate irrigation line, or can one line branch off to supply several raised beds?
Thanks in advance for all your answers 🙂
HarvSpec
13 Aug 2021 11:22
I got a T.I.P. TIEFBRUNNENPUMPEN AJ – AJ 4 PLUS 100/57AUT pump for our cistern.
Do you connect PE-HD pipe directly to it, or use some pressure-resistant flexible hose inside the cistern?
rick201813 Aug 2021 12:04
directly to the HDPE pipe. I believe you have DN 32. That is still flexible enough; in the worst case, you can attach an elbow fitting.
