ᐅ Planning and Preparing a Decentralized Mechanical Ventilation System with Heat Recovery for Residential Buildings
Created on: 10 Aug 2019 21:42
Tassimat
Tassimat
10 Aug 2019 21:42
During my renovation, I unfortunately postponed the topic of mechanical ventilation for a long time, and now I’m unsure whether and how I should install one. I am aware of all the pros and cons, for example from this thread.
My biggest concern is that the fans might be too noisy. Also, there is currently no budget allocated for this.
If I had to prioritize my requirements, I would say:
1. as quiet as possible
2. flexible control
The airflow volume is less important to me, since even an undersized system significantly improves the indoor climate as long as regular ventilation takes place.
At the moment, I am leaning towards the Lunos e² or e²neo for the bedrooms and living areas, controlled via KNX. Even though I originally did not want KNX. Are there any flexible alternatives?
Does it make sense to prepare now by, for example, making 160mm (6 inch) core drill holes, laying cables, and installing the ventilation system later?
Tassimat
Bookstar
10 Aug 2019 22:56
Why not central?
Tassimat
10 Aug 2019 23:17
Without having examined it closely, I would say it is too expensive.
rick201811 Aug 2019 08:07
How many rooms are we talking about? If it’s more than two and the renovation is not yet very advanced, I would reconsider installing a central mechanical ventilation system with heat recovery.
The units you selected, plus core drilling, power supply and control, covers, wiring, etc., will probably cost around 1000€ (approximately 1100 USD) each.
You never wanted KNX before? So currently you don’t have KNX installed and now you want to install KNX just for a few fans?
That doesn’t initially seem very practical.
wrobel11 Aug 2019 11:56
Hello
If quiet operation is a priority, decentralized units should probably be ruled out. Having the fan right next to the bed is likely not the best solution.
Olli
Tassimat
11 Aug 2019 12:21
I understand it will be audible, but there are supposed to be differences between the various systems.
I know you will all recommend a central system, but that would require installing quite a few more pipes, for which I don’t have space. If I had to box in or lower ceiling sections, I would rather do without ventilation altogether.
