ᐅ Placing a BILLY bookshelf made of wood – how to avoid splintered edges?
Created on: 28 Jun 2021 19:43
mepau70
I recently bought the Billy shelf from IKEA and would like to assemble it using wood. However, I have a common problem: the edges, especially where the boards are joined or where the shelves rest, often chip easily.
My question is: how can I set up the BILLY shelf made of wood without the edges chipping during assembly or when placing the shelves? Are there specific techniques, preparation steps, or tools that can prevent this? I want to avoid having broken spots or rough edges after just a few days, as the wood seems quite sensitive.
Thanks for your tips!
Helga
29 Jun 2021 10:36
Karlau’s points are interesting, but the circumstances should be considered in more detail:
The BILLY shelf is made of particleboard with a foil coating, which is naturally prone to splintering if not handled carefully. However, mechanical protective measures (pre-drilling, sanding, painting) work very effectively with this type of construction.
My advice: Score the cut edges with a sharp utility knife before assembly to prevent splinters. Then lightly sand and protect them with a suitable paint or oil.
It’s worth preparing thoroughly—even with furniture made from inexpensive materials.
If you want something completely different, solid wood is an option, but it is usually significantly more expensive.
KNUTGI
29 Jun 2021 11:22
karlau schrieb:
Buy a different shelf, then you won’t have that problem at all.
That may be true, but I think for everyday use it doesn’t have to be the most expensive wooden shelf. With a little attention to detail, even the BILLY boards can be quite sturdy.
My tip: simply avoid hitting them with a rubber mallet, and when assembling, use a piece of cloth or thin cardboard between the surfaces—this really helps prevent splinters.
Add a bit of sanding and apply some oil – done. Setting it up even becomes enjoyable, and the shelf lasts longer without visible damage 🙂
