ᐅ Placing a BILLY Shelf on Delicate Flooring – Should You Use Felt Pads?
Created on: 18 Oct 2024 07:43
Karnli
Karnli
18 Oct 2024 07:43
I’m planning to set up a BILLY bookshelf in my apartment. However, the floor is a very sensitive parquet floor, which I definitely want to protect from scratches and pressure marks. My question is whether it makes sense to attach felt pads under the legs of the bookshelf to better distribute the load and protect the surface of the floor.
Does anyone know the material composition of the BILLY bookshelf legs? Are felt pads recommended for them, or is there a risk that they might come off over time or even damage the floor due to moisture trapped under the felt?
I would also like to know if there are alternative methods or materials that are better suited to protect a sensitive floor, especially for larger pieces of furniture like this. Thank you in advance for your opinions and experiences!
blapau
18 Oct 2024 09:11
Basically, felt pads are a proven way to protect sensitive floors from scratches caused by furniture. In the case of BILLY shelves, the feet are usually made of plastic or wood, which generally works well with felt pads. However, it is important to use high-quality felt pads that are self-adhesive and water-resistant to prevent moisture damage.
Karnli schrieb:
Is there a risk that these might come off over time or even damage the floor through moisture trapped under the felt?
The risk only exists if low-quality products are used or if the surface is not clean and dry before application. Alternatively, you could consider furniture protectors made of cork or rubber if the floor is particularly sensitive or prone to moisture.
Filippo
18 Oct 2024 13:22
I would like to go into more detail about this issue because I have personally placed shelves and furniture on sensitive floors multiple times and have tried different solutions.
First, you should monitor the load on the floor, as BILLY shelves are usually relatively sturdy, but their feet can be small and angular compared to other furniture, which can cause pressure marks. Felt pads reduce slipping in many cases, but standard felt pads sometimes tend to come off under weight and use – which can become a problem when dirt collects underneath.
Therefore, I recommend:
1. Clean and dry the feet thoroughly.
2. Choose special felt pads for wooden furniture with strong adhesive.
3. Alternatively, use coasters or pads made of hardwood or plastic combined with felt to increase the pressure distribution area.
blapau schrieb:
Alternatively, you can also consider furniture coasters made of cork or rubber
This is not wrong, but cork can decompose after prolonged exposure to moisture, and rubber usually leaves dark marks. A combination of a thin hardwood plate with glued-on felt or soft rubber is much more durable and protects the floor better from wear and scratches over time.
What type of floor do you have exactly? Solid hardwood parquet, laminate, or vinyl? This significantly influences the choice of protective layer.
klo61
19 Oct 2024 08:37
I can only confirm what has already been said here.
Felt pads are generally very suitable, especially for parquet or delicate laminate flooring. It is important to check the felt pads regularly. Small stones or dust often collect under the felt due to the movement of the furniture, which can scratch the floor if the pads are not replaced in time.
Another tip:
Make sure that the adhesive layer holds firmly, but still allows you to lift the shelf without damage if necessary. It’s best to buy replacement pads as wear is normal.
If the shelf is heavily loaded, you can also place a thin plastic or rubber sheet between the floor and the felt pad as an additional layer.
If the floor is particularly sensitive, I would recommend small, flat furniture casters with soft wheels, so you can easily move the furniture without damaging the floor.
Palenar
20 Oct 2024 17:56
Very interesting to see the different aspects discussed here.
I would like to add something, as I once faced the challenge of placing a BILLY shelf on very sensitive parquet flooring without causing scratches.
First of all, it is important to know that moisture absorption by felt pads is an underestimated issue. Especially in apartments with higher humidity, felt protectors can actually release some moisture onto the floor or retain it there, which could cause stains or swelling over time.
One solution I chose was to apply a very thin protective film made of transparent vinyl under the felt pads to isolate the moisture. Additionally, the felt pads themselves provide the necessary sliding function.
Furthermore, it is crucial how the piece of furniture is used. If it is frequently moved, the protection should be more robust, as felt wears down with friction. For a shelf that stands still, a felt pad with good adhesion is usually sufficient.
klo61 schrieb:
If the floor is particularly sensitive, I would also recommend small, flat furniture casters with soft wheels
That is a good alternative, although I personally prefer not to put furniture on casters to avoid unwanted shifting. It therefore strongly depends on the individual usage scenarios.
If you like, I can provide specific product recommendations for felt pads and protective materials—just let me know!
