ᐅ Malm furniture warps – how can I prevent this?
Created on: 14 Jun 2019 18:37
Teofa67
Teofa67
14 Jun 2019 18:37
About a year ago, I bought a Malm dresser set from Ikea, and I’ve noticed that the furniture pieces tend to warp over time. This results in crooked doors and slightly sticking drawers, even though I haven’t put excessive strain on the furniture. My question is: How can the warping of Malm furniture be prevented in the long term? Are there any proven tips on how to store, assemble, or treat the furniture to minimize material deformation? I would like to understand whether this is mainly related to the type of wood, the assembly process, or the moisture content, and what end users can do to reduce the problem.
Thanks in advance for your experiences and advice!
Laurence
14 Jun 2019 18:59
Hello Teofa67,
Your question is well formulated and shows that you are already considering multiple causes for the warping.
Regarding Malm furniture from Ikea: These are often made of coated particleboard or MDF, which are generally more sensitive to changes in moisture. Especially in rooms with high humidity, warping can be caused by the material expanding and contracting.
I recommend the following:
1. Control indoor climate: Avoid large fluctuations in humidity (maintaining relative humidity between 40–60% is ideal).
2. Properly level the furniture: Use small shims under the furniture to prevent wobbling and ensure the load is evenly distributed.
3. Assembly: Make sure all screws are tightened properly but not overtightened.
4. Avoid moisture contact: Do not place plants directly on the furniture and protect it from water splashes.
Warping cannot be completely prevented, but these steps can significantly reduce it.
If you have any further questions, feel free to ask! 🙂
mesila
14 Jun 2019 19:45
Hello Teofa67,
I would like to systematically address this topic again because preventive measures are often underestimated here:
1. Consider material properties: Malm furniture is made of veneered particleboard or MDF, which, due to their layered construction and coating, have a certain sensitivity to warping.
2. Assembly: Make sure to assemble the furniture on a flat and dry surface if possible. Uneven assembly can lead to later warping and uneven load distribution.
3. Indoor climate and location:
- Position of the furniture: Avoid direct sunlight because temperature fluctuations and UV radiation can further stress the material.
- Humidity: Fluctuations above 20% are already critical, so using a climate control device or at least a hygrometer to monitor is recommended.
4. Manufacturing process and aftercare:
- Glue and screw points: Sometimes it is worth applying wood glue in addition at sensitive points.
- Surface: There are varnishes and oils designed specifically for particleboard. These provide moisture protection, but you need to make sure they are compatible with the veneer.
Summary: Warping is caused by moisture exposure, uneven stresses, and improper assembly. Regular checks and avoiding extreme conditions are crucial.
If you like, I can provide tips on how to measure and optimize indoor climate.
Jonna
15 Jun 2019 07:03
mesila schrieb:
Make sure to assemble the furniture on a level and dry surface whenever possible.
This is especially important: Furniture that is not installed horizontally can cause stress in the panels, which over time may lead to warping or deformation.
Furthermore, it is helpful to understand the construction method of the Malm wardrobe. The fronts are usually mounted on thinner support panels, which are more sensitive to moisture.
I also recommend not putting any weight on the furniture for at least 24 hours after assembly to allow the joints to settle.
Minor deformations can often be corrected by slightly adjusting the hinges or drawer slides. However, in cases of more severe issues, replacing the warped components is advisable.
bijo54
15 Jun 2019 09:27
Brief and to the point:
- Are the furniture pieces level?
- Is the indoor humidity acceptable?
- No direct sunlight?
If so, the best approach is: avoid overloading and check regularly.
Tightening screws often helps immediately.
TYRELL
15 Jun 2019 11:16
Laurence schrieb:
Especially in rooms with high humidity, warping can be caused by swelling and shrinking of the material.
Exactly, that is the core issue. I would elaborate further because the warping is primarily caused by moisture movement within the panel structure. MDF and particleboard absorb or release moisture depending on the surrounding environment, which causes them to expand or contract.
The direction of the grain and the layering are important. Panels expand more across the grain than along it, which leads to visible warping.
In practice, this means furniture should ideally not be placed against exterior walls with thermal bridges. These areas often have higher humidity and greater temperature fluctuations.
Storage before assembly is also crucial: furniture should only be unpacked and assembled after several days of acclimatization so that the material can adjust to the indoor climate.
Could you describe exactly where you have placed the furniture? Is the humidity in your living space highly variable? Do you use humidifiers or heaters that produce dry air?
