ᐅ Solar power system quote for our single-family home
Created on: 21 Apr 2022 08:45
Elias_dee
Good morning,
Yesterday, we received a quote for a photovoltaic system. Our construction of the single-family house will start in October 2023 and is expected to be ready for occupancy in September 2024.
We have an annual electricity consumption of about 3000 kWh for our household, plus an unknown amount for the air-to-water heat pump (Weishaupt Biblock).
Our roof is oriented exactly south with a 25° pitch (gable roof). According to the calculation in the quote, the entire south roof is fully covered with modules (20 units), and the north roof is also equipped with 5 modules.
Attached you will find the details of the quote. The price is €20,900 net with battery storage and €15,900 net without storage.
What do you think of the offer? From what I understand in the discussions here on the forum, it is advisable to skip the battery storage. That would bring the cost to just under €16,000, which is a bit over €1,600 per kWp. That seems relatively expensive, doesn’t it?
Thank you very much in advance for your help.
Elias
Photovoltaik-Komplettanlage 9,75 kWp mit Q-Cells Q-Peak ML G9 390Wp und SolarEdge-Wechselrichter.
Stückliste: Position, Menge und Text mit K2-Montagesystem, Solarkabel, Erdungsmaterial
Tabelle mit Positionen 8–10: EVU-Anmeldung, Meßprotokoll, Inbetriebnahme; Gesamtpreis 20.900,00 €
Fuchur
24 Jun 2022 08:09
Is it because only the model is available, or is there another reason? It doesn’t really make sense.
Neubau2022
24 Jun 2022 09:18
Fuchur schrieb:
Is it because only the model is available, or what is the reason? It doesn’t really make sense.
Are you referring to me? I don’t understand the context 😎
Fuchur
24 Jun 2022 09:29
The overview is lost on mobile... A 17kW inverter for a 13kWp generator doesn’t make sense, but nowadays inverters are hard to get as well.
Neubau2022
24 Jun 2022 09:34
Fuchur schrieb:
The overview gets lost on mobile... A 17kW inverter for a 13kWp generator doesn’t make sense, but nowadays inverters are hard to come by as well.
You say a larger inverter is needed, but on the other hand, it’s too big? We also plan to build a carport and probably install photovoltaic modules there.
Pitiglianio
24 Jun 2022 10:48
Neubau2022 schrieb:
You say a larger inverter is needed, but on the other hand, it is too big? We are also planning to build a carport and probably install photovoltaic modules there.
I think @Fuchur meant the 10 kW inverter for the 14.4 kWp system from @Malz1902
Malz1902
24 Jun 2022 12:20
According to the simulation, 10 kW (kilowatts) are sufficient here because the southeast/northwest orientation prevents peak loads from ever being reached.
