ᐅ Solar power system quote for our single-family home
Created on: 21 Apr 2022 08:45
Elias_dee
Good morning,
Yesterday, we received a quote for a photovoltaic system. Our construction of the single-family house will start in October 2023 and is expected to be ready for occupancy in September 2024.
We have an annual electricity consumption of about 3000 kWh for our household, plus an unknown amount for the air-to-water heat pump (Weishaupt Biblock).
Our roof is oriented exactly south with a 25° pitch (gable roof). According to the calculation in the quote, the entire south roof is fully covered with modules (20 units), and the north roof is also equipped with 5 modules.
Attached you will find the details of the quote. The price is €20,900 net with battery storage and €15,900 net without storage.
What do you think of the offer? From what I understand in the discussions here on the forum, it is advisable to skip the battery storage. That would bring the cost to just under €16,000, which is a bit over €1,600 per kWp. That seems relatively expensive, doesn’t it?
Thank you very much in advance for your help.
Elias
Photovoltaik-Komplettanlage 9,75 kWp mit Q-Cells Q-Peak ML G9 390Wp und SolarEdge-Wechselrichter.
Stückliste: Position, Menge und Text mit K2-Montagesystem, Solarkabel, Erdungsmaterial
Tabelle mit Positionen 8–10: EVU-Anmeldung, Meßprotokoll, Inbetriebnahme; Gesamtpreis 20.900,00 €
Snowy36
30 Apr 2022 22:41
Fuchur schrieb:
The basement is ideal for the battery, mainly because of the constant temperatures throughout the year. That’s where mine is located as well. I wouldn’t keep it in the garage, as it can get very cold there during winter.
BYD specifies that the battery can withstand -10°C (14°F) ... we will insulate it further.
Fuchur
30 Apr 2022 23:26
Snowy36 schrieb:
BYD specifies that the storage can withstand -10 degrees…
Correct, "withstand". If it gets colder, do you dismantle it or rely on the insulation effect?
By the way, BYD's statement comes with the footnote that "performance is reduced from -10°C (14°F) to +5°C (41°F)" – whatever that means in detail.
Snowy36
1 May 2022 00:59
I don’t think my garage will drop significantly below 0°C (32°F)… even in the garden shed, the olive tree survives winter without heating.
Tolentino1 May 2022 08:03
If necessary, install frost protection. Although I am not sure to what extent this counts as a heating appliance.
Snowy36
4 May 2022 14:12
Degree in the Swabian region, just google “Explosion hazard: photovoltaic system battery storage as a ticking time bomb in single-family homes” 🙂
i_b_n_a_n4 May 2022 14:20
Tolentino schrieb:
If necessary, install frost protection. Although I’m not sure to what extent it counts as a heating appliance.
Heating appliances are defined here as oil, gas, pellet (or firewood, etc.) systems. Heat pumps or frost protection devices (electric) are not considered heating appliances.
