ᐅ What are the advantages of 24mm perimeter insulation?
Created on: 12 Jul 2020 11:29
Smarti99
My entire foundation slab is above ground level. On top of that, there will be Poroton blocks and a floor construction 20 cm (8 inches) thick.
Would I gain a significant advantage if I insulate the 24 cm (9.5 inches) perimeter of the foundation slab?
michert
12 Jul 2020 13:21
Do you want to leave it out or what? I think the picture clearly shows why uninsulated corners are problematic..
Smarti99
12 Jul 2020 13:27
Yes, I want to leave them out.
But you can see that despite the insulation, there is no noticeable difference in temperature, especially because the masonry still feels very cold on the outside.
michert
12 Jul 2020 13:34
You can’t really judge that based on the picture. I assume you are building with solid construction without external thermal insulation composite systems (ETICS). However, the picture shows a wall assembly with ETICS. Omitting insulation under the slab already has the potential to cause problems.
The person responsible for calculating the energy performance certificate (EPC) will be able to answer your specific question. Only that person knows the exact conditions and can assess the entire system.
