ᐅ Pergola Attached to Facade / Waterproofing
Created on: 21 Nov 2023 12:45
Coletrickle_7808
Coletrickle_7808
21 Nov 2023 12:45
I am going to install a pergola / louvered roof on our terrace. It will be freestanding and set on pad foundations.
I would like to position the louvered roof against the facade. To protect the plaster and ensure it is waterproof, I am thinking of using compressible sealing tape to seal the small gaps or unevenness in the plaster. I would place this between the facade and the pergola.
Is this suitable, or is there a better alternative?
Tolentino21 Nov 2023 13:03
Compressible foam tape yes, but also a wall connection profile (usually made of aluminum).
Coletrickle_7808
21 Nov 2023 13:09
Is a wall connection profile really necessary?
I wanted, if possible, not to damage anything on the facade.
It is the south side, with an 80cm (31.5 inches) roof overhang, city villa…
Tolentino21 Nov 2023 13:10
Otherwise, it probably won't be watertight. You could try searching online to see if there are profiles that are only glued.
Coletrickle_7808
21 Nov 2023 13:23
Water normally does not reach that area anyway… I usually have about 40cm (16 inches) of clearance, probably thanks to the overhang. I just want to be cautious.
WilderSueden
21 Nov 2023 13:28
With wind, rain regularly reaches 2 meters (6.5 feet) deep under our patio roof. During storms and thunderstorms, the rain can sometimes reach waist height against the patio door, which is at 3.5 meters (11.5 feet) deep. An overhang of 80 centimeters (31.5 inches) will protect you from normal rain showers, but you will still frequently experience rain in that area.
