ᐅ Rear baseboard of Pax broken – does this affect stability?
Created on: 4 Jan 2024 08:43
HorstBenken
HorstBenken
4 Jan 2024 08:43
Good morning,
I made a mistake: while moving my Pax wardrobes over a high-pile carpet, the rear baseboard on one unit broke off at the bottom and is now detached. The wardrobe is 1 meter wide and 2 meters high (so a 1-meter cabinet). As far as I can tell, it still stands securely and stable (mainly resting on the side panels). Does the baseboard need to be replaced, or can I leave the wardrobe as it is?
On the other wardrobe (same dimensions), one adjustable foot broke off. It doesn’t actually bear any weight, right?
I know... it was a silly move, but that’s how it happened.
The two wardrobes are placed side by side. Would you fix them to the wall with a bracket or screw them together at the top?
Horst
Jesse Custer
4 Jan 2024 09:53
As far as I know, Ikea requires them to be attached to the wall using the strap anyway...
elminster
4 Jan 2024 17:52
I don’t think I would take everything apart for that reason. It would also depend on whether there are water tanks or plinths inside the cabinet.
What I would definitely do, however, is connect the cabinets together (Ikea screws are included for this, but you can also use wood screws) and secure each one to the wall with brackets.
Fabienne9520 Feb 2024 10:34
elminster schrieb:
I don’t think I would take everything apart just because of that. It would also depend for me whether there are water tanks or kickboards in the cabinets.
What I would definitely do is connect the cabinets together (Ikea includes screws for this, but you can also screw them together yourself) and secure each one to the wall with an angle bracket.
I agree—there’s no need to disassemble everything, especially if water tanks or kickboards are involved. The idea of connecting the cabinets to each other and to the wall is definitely a good one and improves stability. That’s exactly how I would do it as well.
