Hello, we really like paved paths and surfaces. We already have them. However, what really bothers us is how quickly the joints fill with persistent weeds, and after 16 years, the algae growth (circular patches) has become unattractive. This algae is very firmly attached and can hardly be completely removed anymore.
My question is: Are there any recent developments to control both issues? Otherwise, what would be an alternative to paving? It should definitely be durable and low-maintenance, as the areas are large. Best regards, Steffi33.
Knallkörper26 Sep 2016 14:57Gly*h**at, then you’re set, it works 100% and is long-lasting; one dose per season is enough.
Knallkörper schrieb:
Gly*h**at, then you have peace, helps 100% and sustainably, one dose per season is enough. This is not permitted on sealed surfaces, nor in residential and allotment garden areas. Purchasing it usually requires proof of expertise, at least for larger quantities.
Although, salt is also generally not allowed for this purpose. 😉
Knallkörper26 Sep 2016 16:21FrankH schrieb:
This is not permitted on sealed surfaces, nor in residential and small garden areas. Usually, purchasing it requires proof of expertise, at least for larger quantities. However, salt is generally not allowed for this purpose either.;)Do you mean glyphosate? In that case, you’d be right 😉
Seriously: Farmers spray this substance on fields after plowing. There is then a waiting period of 2 days before new crops can be planted there. And I’m not supposed to spray it on the driveway? Sure 😉
Are you referring to glyphosate? In that case, you’re absolutely right 😉
Seriously: Farmers spray this stuff on the fields after plowing. There is then a waiting period of 2 days before planting new crops. And I’m not supposed to spray it on the driveway? Sure 😉 I never said you always have to understand legal regulations. 😉
But the warning is still useful for laypeople; at least people should be aware that they are taking a legal risk.
Bieber081527 Sep 2016 07:08I would be interested in the legal regulation regarding the ban in allotment gardens (so far, I have only found a text from 2004 stating that "the ball is now with the federal government").
It is not allowed on paved surfaces because it can run off these surfaces directly into the water cycle. This prohibition should definitely be observed!
Bieber0815 schrieb:
I am interested in the legal regulation regarding the ban in allotment gardens (so far, I have only found a text from 2004 stating that "the ball is now in the federal government's court"). I found the following on this issue:
The Plant Protection Act dated 06.02.2012 and the Authorization Regulation VO (EC) No. 1107/2009 regulate, among other things, the use of plant protection products in private and allotment gardens.
