ᐅ Uneven and loose paving – what can help?
Created on: 1 Mar 2019 08:24
kaho674
we recently had our driveway paved with natural stones. Unfortunately, I am not satisfied with the result. Many stones are still loose, and the surface is extremely uneven. We had a pathway paved with the same stones about 2 years ago, and that one turned out perfect.
I have already spoken with the builders, and we will find some kind of agreement. However, they are not professional landscapers but rather a general construction team that handles various tasks. (After 4 companies didn’t even submit a quote, we were just glad they finally agreed to do it.)
The main question is: How can I make the already laid stones as level and firm as possible? We are now trying to get a heavy (700 kg (1,540 lbs)) vibrating plate, as the previous one was too weak. Will that be enough to level everything properly?
kaho6741 Mar 2019 12:01
Okay, so that means straightening out all the uneven parts, refilling with gravel, and then compacting again. That’s a bit of a hassle.
haydee
1 Mar 2019 12:07
Yes, there probably is no other way. If there is enough uncompacted gravel beneath the stones, you will eventually get them to hold, but the surface will become increasingly uneven.
hemali2003
1 Mar 2019 16:09
How heavy was the vibrating plate?
But usually, the surface looks more uneven before compacting than afterward, not the other way around...
kaho6741 Mar 2019 18:00
We just talked to a neighbor who used to work in road construction. He said the small plate compactor was more like a toy and that he was already surprised while watching.
Next week, a 200kg (440 lbs) machine will arrive, which is supposed to smooth everything out. The stones that have settled will be removed and reset, and then the whole process will be repeated until it’s right. Let’s hope for the best.
haydee
1 Mar 2019 18:12
It depends on how much uncompacted gravel and sand are underneath.
Make sure the 200 kg (440 lbs) slab has more stiffness than the smaller one and roughly the same bearing area. Weight isn’t everything.
3 Mar 2019 01:08
kaho674 schrieb:
At the bottom is gravel, which is very compacted, then they used additional gravel to level it out and finally a bit of sand so the stone sits evenly.
The sand disappears into the air gaps of the gravel layer... it basically sinks in, and in an uncontrolled way.
