We want to pave our driveway. It’s easily over 100m² (1,076 sq ft). We have quotes around 6,500€. Now I'm really feeling a bit stingy and wondering if it’s something we can do ourselves? It’s not exactly rocket science, right? Has anyone here done their own paving? Is it possible for a layperson to handle 100m² (1,076 sq ft) on their own?
SteffenBank22 Jun 2017 08:20Ideally, the base layer should be even, without large depressions. Differences of 2-4 cm (1-1.5 inches) can already have an impact when compacting the paving and may cause depressions to form later on the surface, as the gravel could still settle over time.
naitxtian22 Jun 2017 08:23So, just scrape it off [emoji24]
SteffenBank22 Jun 2017 08:25Or filling holes, I've also been distributing and compacting since yesterday.
naitxtian22 Jun 2017 08:26Then the heights no longer match...
Knallkörper22 Jun 2017 11:17Split won't settle – where would it go?
If your paving stones aren't too small-sized, I wouldn't worry about it, even though I don't have a picture of the damaged areas.
SteffenBank22 Jun 2017 11:22Knallkörper schrieb:
Split doesn’t settle – where would it go?
...If that’s the case, then there shouldn’t be a problem. I just thought that even gravel could compact. Otherwise, vibrating the paving stones wouldn’t do much, apart from helping the joint sand settle better.Similar topics
