ᐅ Passage beneath a staircase
Created on: 13 Feb 2015 11:10
abertram
abertram
13 Feb 2015 11:10
Are there any members here with experience having a passageway under a staircase? We are currently working on the floor plans with our construction company, and the attached suggestion came up. What do you think about it?
Regards,
Alex
13 Feb 2015 11:27
abertram schrieb:
Are there any members here who have experience with a passageway under a staircase?
Yes... although "experience" might not be the right word. You don’t gain any special benefit from this arrangement. As long as the dimensions are correct and it is designed by a professional, the location of such a door or passageway is basically nothing noteworthy.
Regards, Yvonne
abertram
13 Feb 2015 11:47
It could have been the case that there are disadvantages which are not immediately obvious and that would rule out this solution from the start. But if that is not the case, then I am glad.
Jaydee13 Feb 2015 12:30
We have that too – however, the door under the stairs only leads to the utility room, so our guests don’t have to constantly duck under the stairs.
Would it be possible to switch the utility room and office/restroom in your layout? I think that would be nicer…
kbt09
13 Feb 2015 12:59
If the sketch should already match the staircase length and other dimensions, you should take a look at a staircase with a rise of 19.8 cm (8 inches) and a tread depth of only 25 cm (10 inches) beforehand. This corresponds to a so-called step length of 64.8 cm (25.5 inches), while 63 cm (24.8 inches) is considered ideal.
Step length formula = 2 x rise + 1 x tread depth … IDEAL: 63 cm (24.8 inches) … in your case: 64.8 cm (25.5 inches)
Comfort formula = tread depth - rise … IDEAL: 12 cm (4.7 inches) … in your case: 6.2 cm (2.4 inches)
Safety formula = tread depth + rise … IDEAL: 46 cm (18.1 inches) … in your case: 44.8 cm (17.6 inches)
abertram
13 Feb 2015 13:06
Jaydee schrieb:
Would it be possible for you to swap the utility room and the office/bathroom? I think that would be nicer...
I have already considered that, but we want a secondary entrance from the garden/carport, and all of that is located where the utility room is now. So swapping them is rather not feasible.
kbt09 schrieb:
If the sketch is supposed to match the stair length and so on, you should take a look at a staircase with a 19.8cm (7.8 inch) rise and only a 25cm (10 inch) tread depth first. That corresponds to a so-called step measure of 64.8cm (25.5 inches)... 63cm (24.8 inches) is considered ideal...
That’s a good tip, thanks. I’ll do some research.
Regards,
Alex
