ᐅ Parquet Flooring on Underfloor Heating – Is Thermal Resistance a Concern?
Created on: 24 Feb 2018 21:17
blaupuma
We are planning to have oak parquet flooring installed. Today, at the specialist store, we were advised to have the flooring glued down. This supposedly eliminates the need for insulation and is better for underfloor heating. In general, parquet is not ideal for underfloor heating (the heat does not transfer as well as with other floor coverings).
Has anyone had extended experience with this? What should be considered?
By the way, the installation is supposed to cost 30 euros per square meter (about 3.3 square feet) [emoji15]—15 euros for the installation and 15 euros for the adhesive.
Thank you very much for your input.
Domski
25 Feb 2018 13:45
I installed Bona R777, costing about €7/m² (50€ for a 7kg (15.4 lbs) container), plus an additional €2-3 for PU primer.
blaupuma25 Feb 2018 14:02
The slow response of the heating system doesn’t really matter, does it?
It’s the same with the insulated ground slab.
We also have underfloor heating now, and basically the settings stay the same all year round. Who keeps constantly adjusting the temperature up and down anyway?
Mycraft25 Feb 2018 14:13
Nobody does, yet there are always warnings about the so-called harmful hardwood flooring… The heat still enters the house regardless.
Alex85
25 Feb 2018 14:41
Parquet flooring is not a dealbreaker, but there are definitely better and less suitable products available. The suitability is indicated by the manufacturers.
Wood has insulating properties, which cannot be denied.
Blondblau
25 Feb 2018 15:09
Our general contractor included €110 (with €40 for materials) per m2 (10.8 sq ft) for parquet flooring in the Berlin area in the quote, so the amounts mentioned here seem quite moderate.
Blondblau
aero2016
25 Feb 2018 17:40
Lumpi_LE schrieb:
In all physical and heating-related matters, a completely incorrect statement @aero2016 ...
If you assume the house is a closed thermal system (which of course it is not, but ideally it would be), then the first law of thermodynamics would suggest otherwise. The heat that is generated has to go somewhere. It doesn’t just disappear into the air, does it?
