ᐅ Painting work: which type of paint, with or without non-woven wallpaper?
Created on: 27 Nov 2017 13:48
Paulus16
we will have lime-gypsum plaster with quality level Q3 in our house. Wallpaper is not desired.
We are currently getting quotes for painting work. I have two questions:
-I would like to use mold-resistant paint, possibly lime-based. The two painters I asked said that in all new buildings they have only used standard dispersion paint and have had no problems with mold. Only in damp rooms like the bathroom could they add fungicides if desired. Are my concerns about mold justified, or am I overreacting a bit? What are your experiences?
-One painter offers fleece on the ceiling, the second one also on the walls. What do you think about using fleece or not?
Thanks in advance
Thanks in advance
When a wall dries, it loses water and, therefore, volume. However, in our walls, cracks have appeared since July in exactly one spot. Why is that? I think there is hardly any water in the Ytong masonry due to the adhesive. The plaster on top is not thick enough to handle shrinkage without cracking. An exception is the cable channels. There, the plaster is thick, which tends to crack. Let it dry out, apply a quick-drying filler, repaint, and done.
We also have Q3, although that is always quite subjective... our walls are very smooth, gypsum plaster, and even with raking light you can’t see any unevenness. We had them painted right away, but with silicate paint; I wouldn’t want to apply dispersion paint on the walls. We only used fleece on the ceilings, as otherwise you can find a few small cracks here and there.
This is certainly also a matter of personal belief.
Gypsum plaster can quickly absorb large amounts of water vapor and evenly release it again, which leads to smaller fluctuations in humidity (for example, when cooking, many people in the room, etc.), contributing to a comfortable indoor climate.
Using dispersion paint removes this property from the plaster, which simply doesn’t make sense.
Then there are the additional benefits, such as being fungicidal...
And quite subjectively: when comparing two sample areas, silicate paints simply look better.
The downside is (at least according to the painter) that you shouldn’t paint this yourself. If you don’t know what you’re doing, it quickly becomes blotchy and uneven, making touch-ups almost impossible, and the paint isn’t particularly health-friendly during application either.
