ᐅ Painting KALLAX with spray paint – does it cover well?
Created on: 23 Jan 2019 08:37
joben59
I’m planning to paint my KALLAX shelving unit from IKEA using spray paint and wondering how good the coverage usually is for a project like this. I’ve read that the surface of the KALLAX is quite smooth, which might make painting more difficult – the paint could apply unevenly or be thin in coverage.
Has anyone had experience with this and can say if spray paint alone is enough, or if it’s better to sand the unit beforehand or use a primer? Also, how many coats should be applied at minimum to achieve a fully opaque and durable finish?
I would also appreciate any tips on suitable spray paints and techniques. Thanks in advance!
Guyju
25 Jan 2019 22:34
Here is a summary of how I and many people in my circle have successfully treated KALLAX with spray paint:
1. Preparation:
- Lightly sand the surface (220 grit sandpaper, preferably using a sanding block for even pressure).
- Remove dust and thoroughly degrease (e.g., with denatured alcohol).
2. Primer:
- Use an adhesion primer, ideally melamine-based.
- Allow the primer to dry sufficiently (at least 2 hours).
3. Spray paint:
- Apply 2-3 thin coats, with about 15 minutes drying time between coats.
- Use matte or satin white spray paint, preferably furniture or plastic lacquer.
4. Protective topcoat:
- Apply a clear coat in matte or satin finish for added durability.
Common mistakes:
- Applying coats too thickly, which causes dripping or uneven coverage.
- Painting directly on melamine-coated surfaces without primer.
If you only have an inexpensive acrylic spray paint, primer and careful application will definitely suffice. For the best durability, however, I would recommend using two-component (2K) coatings.
