ᐅ Painting IKEA Malm Furniture – Which Paints Are Suitable?
Created on: 22 Jul 2021 09:37
raga32
raga32
22 Jul 2021 09:37
I am planning to paint my IKEA Malm furniture to give it a personalized look. I am wondering which paint colors would best suit this furniture design. The surface of the Malm series is quite smooth and modern, usually available in white or black-brown. My idea is to choose a color that not only complements the furniture itself but also fits well with a Scandinavian-minimalist interior style.
Does anyone have experience with which paint finishes tend to look particularly harmonious, and are there any specific recommendations for preparing the surface? For example, should I use more of a matte or glossy paint? I am also interested in how durable different paint types and colors are in everyday use.
Looking forward to tips and color suggestions that have worked well so far. Thanks in advance!
blapau
22 Jul 2021 11:02
Hello raga32,
to keep it brief: Proper surface preparation is crucial if you want a good result. The Malm furniture has a coated surface that you should lightly sand first to ensure better paint adhesion. Make sure to use fine sandpaper with a grit of 220 or higher.
Regarding the colors: For a Scandinavian minimalist style, neutral tones like warm gray, soft blue, or muted pastel pink work well. These colors are timeless and won’t change the furniture’s appearance too much. Matte finishes are recommended because they are less prone to fingerprints and complement the Scandinavian style nicely.
For durability, you can rely on a high-quality acrylic or polyurethane paint – both are durable and easy to maintain.
I hope this helps you.
draleo
22 Jul 2021 15:47
Additionally, I would like to provide some technical details about painting the MALM furniture.
Since these are chipboard panels with a foil-coated surface, it is important to roughen this surface before painting to avoid adhesion issues. You can achieve this with fine sandpaper or a sanding pad. Afterwards, it is recommended to apply a primer specifically designed for smooth plastics or foil surfaces (adhesion promoter). Without this primer, the paint tends to peel off.
Regarding color selection:
- Matte finishes work well with the minimalist style, as they emphasize the furniture’s clean lines and reduce reflections.
- Colors like anthracite, dusty blue, or sage green offer subtle contrast without being too bold.
- Light beige or sand tones also fit the Scandinavian look.
For durability, the furniture should be sealed after painting with a clear acrylic varnish to make the surface more resistant to scratches and stains.
To answer your question about durability: matte paints for indoor use typically last several years without major issues, provided that preparation and sealing are done carefully.
If possible, I recommend testing on an inconspicuous area first to check adhesion and appearance.
Ethan
23 Jul 2021 08:13
blapau schrieb:
matte finishes are recommended because they are less prone to showing fingerprints
That’s true, I also mostly use matte finishes. I painted a MALM dresser in a soft mint shade. The color matches perfectly with the light wood of the other furniture and looks fresh without being too bold.
As mentioned, proper preparation is essential: clean thoroughly, lightly sand, prime, and only then apply the paint. By applying several thin layers, you avoid uneven spots.
Regarding the color: pastel tones and muted colors appeal to me the most for MALM, as they don’t overpower the modern style but rather emphasize it.
If you like bright colors, I would suggest using them more on smaller furniture or accessories since large surfaces like drawer fronts can easily become overwhelming.
Looking forward to seeing which color you choose! 🙂
LOGEMIN
23 Jul 2021 16:29
Hello raga32,
I would like to share a brief step-by-step guide for painting MALM furniture, which I have found very helpful:
1. Empty the furniture and ideally disassemble it to easily reach all surfaces.
2. Clean the surface using a grease-dissolving cleaner (e.g., denatured alcohol) to remove dust and grease.
3. Lightly sand the surface using 220-grit sandpaper or a sanding pad to roughen the smooth coating. Avoid sanding too aggressively to prevent damaging the particleboard.
4. Remove dust with a damp cloth and then let it dry.
5. Apply a primer, specifically an adhesion promoter for foil surfaces – this helps the paint adhere better.
6. After the primer has dried, apply two thin coats of paint, preferably acrylic paint in your desired color. Lightly sand between coats with 320-grit sandpaper for improved adhesion.
7. Finally, seal the surface with a clear coat (matte or satin finish) to protect it and increase durability.
My color recommendations: warm gray, sage, or a softly muted blue work well. Avoid very dark or very bright colors on large furniture pieces, as they can feel heavy.
Important: Always test the paint on a small area first! This way, you can see how the color looks and whether the paint adheres properly.
I hope this helps you with your project!
