ᐅ Painting borders using stencils. Does anyone have experience with this?
Created on: 1 Sep 2008 16:42
gatita
gatita
1 Sep 2008 16:42
have any of you ever painted borders using stencils? I bought a stencil and plan to start the project in the next few days. However, I’m a bit concerned about the paint bleeding. The design will be applied in three different colors. If I fix the stencil with painter’s tape, as the instructions say, I worry that the paint might seep underneath. Is that really the case, or is it easier than I currently imagine? Thanks for your help! 🙂
makler01
13 Oct 2008 08:28
Hello! It depends on which colors you use. I have done something similar before using self-adhesive stencils and simple poster paints. Nothing ran or smudged, and it still looks great. Best regards, Liane
Maier GmbH
14 Oct 2008 09:30
I have tried something like that as well. The only problem is if you apply too much paint at once. Then it will, of course, run. But if you work with a sponge, for example, it works great!
Maier GmbH
14 Oct 2008 09:33
Yes, I also think it depends on the type of paint... if they are too liquid, they will run, but poster paints are quite suitable for this kind of work, you just shouldn’t dilute them too much.
tfmStudentin
25 Oct 2008 16:18
This is really not that difficult! You just have to be careful not to apply too much paint, otherwise it can run. But other than that, it’s not hard. One more tip: wait until the paint is partially dry before removing the stencil, to further prevent smudging! Good luck!! 🙂
