we are currently finishing our house. In our new build, which has now taken 6 months, Q2-level gypsum plaster was applied to the walls.
What is better for a new build that has not yet been exposed to frost: filling and painting directly, or applying a painter’s fleece first and then painting?
Many thanks and best regards,
Ani
Ani
Maybe a small tip for homeowners during construction: when you paint, it’s better to get a little more paint than you think you’ll need. We have already touched up several areas after moving in and even later on. For example, in the stairwell where vacuum cleaners, suitcases, or travel bags can brush against the walls.
Corners and edges that our cat frequently passes by also tend to get dirty quite quickly. We didn’t notice this as much on the wallpaper in our previous apartment.
We only painted our gypsum plaster as well. However, we had an agreement with our plasterer to make the surface as smooth as possible so that we could paint it ourselves. It only needed to be primed and then painted. It looks good. The important thing is not to use the cheapest paint.
3
321_meins28 Sep 2015 08:56Patchwork schrieb:
that depends on the size of the house. How many square meters is it? The ceiling area is 145 m² (1,560 sq ft), and the wall area is 411 m² (4,425 sq ft).
