ᐅ Outdoor electrical outlet / wall-mounted box or column
Created on: 26 May 2015 13:25
Doc.Schnaggls
Doc.Schnaggls
26 May 2015 13:25
We would like to install (ideally) four outdoor outlets at our barbecue area.
A separately protected underground cable is already laid in the ground and comes vertically out of the ground at the barbecue spot.
We would prefer a four-gang outdoor outlet with a stone-look finish (cover opening forward) or a stainless steel pedestal with four outlets as well.
Has anyone had experience with these types of outdoor outlets?
Regards,
Dirk
26 May 2015 13:31
Do you want to do electric grilling? 😀
We have a pedestal.
The question about experience is difficult for me... They work, electricity flows!
Doc.Schnaggls
26 May 2015 13:46
Electric grilling? 😕
No, rather not... 😱
Seriously, it’s more about possibly providing lighting for the gazebo or mainly a power supply for the pellet smoker...
Would you mind telling me which manufacturer your column is from?
26 May 2015 14:07
I'll have to check that tonight... my husband is the expert when it comes to technical stuff 😉
Doc.Schnaggls
26 May 2015 14:10
Thank you!
26 May 2015 16:59
Hello Dirk,
it’s a power outlet column from Greencraft. I assume it was bought at Obi. My husband doesn’t order online 😉
Details:
- Height 510 mm (20 inches)
- 2 power outlets
- switched together
- each outlet can be switched ON/OFF/manual timer with a hand switch
- 5 m (16 ft) cable
- mounting base and ground spike
- solid plastic duct
- 3 cable entries for up to 5 x 2.5 mm² (13 AWG) conductors
- base diameter 170 mm (7 inches)
Costs around 50 €
It looks very ugly, but has separate switches and a timer. For us, it’s nicely hidden in bamboo 🙂 otherwise, he would have had to replace it 😉
