ᐅ OSB boards or tongue-and-groove planking for the floor in a convertible attic?
Created on: 23 Feb 2019 21:39
hauspeter- We are building a bungalow with an expandable attic space featuring a 38-degree roof pitch.
- The intermediate ceiling already has a vapor barrier and insulation installed.
- The roof beams are approximately 24cm (9.5 inches) high and spaced 50cm (20 inches) apart, with insulation in between.
- The mineral wool insulation is about 16cm (6.3 inches) thick.
The roof was originally intended to remain unheated (cold roof). However, we are also considering adding insulation next summer. We have read about mold issues with OSB boards and cold roofs because, unlike tongue-and-groove boards, OSB is vapor-tight.
- Are 22mm (7/8 inch) or 25mm (1 inch) OSB boards or 24mm (15/16 inch) tongue-and-groove boards better suited for the subfloor?
- Is a counter batten system useful to allow ventilation between the beams, or should the OSB boards be laid directly on the beams?
- Should the boards be fixed with screws or installed as a floating floor?
Stefan2.8416 Mar 2021 07:04Hello everyone, I have covered the first half of the attic floor with tongue-and-groove boards. Now I want to install some additional insulation between the rafters to prevent it from getting too cold or too hot. However, I’m still unsure about the vapor barrier. I have already installed one, but I didn’t make sure it is completely sealed to all the other building components. For me, the vapor barrier is just supposed to keep the insulation from being exposed. Is that okay? Or does the vapor barrier still need to be perfectly sealed even in a somewhat leaky attic?
Thanks and best regards
hauspeter16 Mar 2021 22:11If you have a vapor retarder in the ceiling between floors, that would not be a problem. Without an additional vapor retarder, your insulation could become damp. To answer this properly, one should understand the purpose of a vapor barrier or vapor retarder.
The goal is to protect the insulation from moisture coming from the indoor air. Dust protection or the physical separation from the living space is a secondary effect.
So,
- Do you already have a vapor retarder in the ceiling between floors? This is common in bungalows with cold roofs.
- Does the roof have a vapor-permeable underlay membrane beneath the roof covering? This protects against rain but allows water vapor to pass through to the outside.
So,
Stefan2.8417 Mar 2021 07:21Hello and thank you for your feedback. I can answer both questions with yes. There is a vapor retarder on the ceiling of the upper floor (gable roof with an unheated attic). And there is a vapor-permeable underlay beneath the roof covering.
Appel200030 Mar 2021 22:21Hello!
So, how did you end up solving the issue?
Stefan2.8431 Mar 2021 07:08Hello, I haven’t done anything yet. I’m still not sure exactly what I should do now 🙂
