ᐅ Ordering Additional Parts for BILLY Shelving – Which Ones Are Really Necessary?
Created on: 23 Feb 2023 14:27
JOSE30Hello everyone, I am currently planning to expand my BILLY shelf and am unsure which of the many available accessories are really necessary to meaningfully improve functionality and stability without spending unnecessary money. Specifically, I am wondering if stronger back panels, compatible shelves with metal reinforcement, or practical basket inserts are truly worth it. I am also considering whether additional shelf supports make sense when installing multiple shelves. Does anyone have experience with which parts actually add value, which are rather unnecessary, and what to really pay attention to when ordering? Thanks in advance for your input!
Hello JOSE30, if the shelf needs to hold a lot of weight, I strongly recommend metal reinforcements and stronger back panels. Basket inserts are more a matter of convenience and should only be considered if you frequently want open storage. Additional shelf supports make sense only if you plan to install many or heavy shelves.
Hello JOSE30, your question is very well posed, as every detail counts when extending a BILLY shelving unit for optimal use. First, it is important to clarify what you primarily intend to use the shelf for and what loads it will need to carry. The standard back panels of BILLY units are usually made of thin hardboard and serve both an aesthetic purpose and provide some stability against sideways movement. However, if your shelf is going to store heavy books or equipment, a stronger back panel is definitely recommended, as it better prevents warping.
I agree with that; the metal reinforcements on the shelves significantly increase load capacity because they distribute weight more evenly and prevent bending. However, you should ensure that both the reinforcements and the appropriate screws for mounting are installed correctly. A common mistake is uneven load distribution when the shelf supports or fasteners are not positioned precisely.
Regarding the basket inserts: these are especially useful for modern uses of BILLY shelves as flexible storage solutions. They make accessing smaller items easier. However, they are not necessarily required, especially if you use the shelf exclusively for books or boxes. In conclusion, I recommend making a detailed list of the expected loads and intended uses before ordering, and then deciding which extras make sense. How do you plan to outfit the shelf?
EDWARD0 schrieb:
if the shelf will carry a lot of weight, I definitely recommend metal reinforcements and stronger back panels.
JOSE30 schrieb:
whether, for example, stronger back panels, suitable shelves with metal reinforcement, or practical basket inserts are really worth it.
The advice from bapar is very sensible: first, clearly define the intended use. For heavy loads, stronger back panels and metal reinforcements on the shelves are essential. However, if the shelving unit is mainly meant to expand storage for light items or decorations, the standard version is usually sufficient.
I would also recommend choosing original IKEA parts when ordering and not relying too much on third-party products, as these often cannot match the exact fit and stability. Be sure to read the assembly instructions carefully, as some additional parts require a specific sequence or tools. Personally, additional shelf supports have never hurt me with more than 5 shelves, but they are not always necessary with BILLY.
In summary: add extras only where your specific use case calls for them. This helps avoid costly mistakes.
