ᐅ Optimally Equipping Ikea Metod Tall Cabinets with LED Lighting Systems
Created on: 14 Oct 2023 08:17
Mar47
Hello everyone, I am currently looking into the optimal lighting for IKEA Metod tall cabinets and am seeking recommendations or experiences specifically with LED systems. My main question is: How can a uniform and adequately bright illumination of the interior of the tall cabinets be achieved without making the installation too complicated or requiring complex integration of external power sources? I am particularly interested in which LED strips or recessed modules work best, how to mount them effectively, and how to design the system smartly so that the lighting can ideally be controlled by a sensor or switch. Who has completed similar projects and can share tips, for example regarding the LED technology used, wiring, installation options, and control methods? Thanks in advance for your input!
peovin
14 Oct 2023 17:03
My tip: Use 12V LED spotlights with direct wiring. These are dimmable and can be easily recessed into the shelves. Together with a motion sensor near the door area, this works very well. This way, you can avoid shadows and still have practical control.
Mar47
15 Oct 2023 08:48
kasan schrieb:
I would like to point out that when using pre-assembled LED modules, there is often the problem that they do not fit exactly in the depth of Metod cabinets or emit too much light backward, which wastes energy unnecessarily and can cause reflections.
That is a very good point. I want to avoid wasting light output or creating too much stray light. Does anyone have experience with aluminum profiles that can be installed inside the cabinets? Are there any recommendations for covering diffusers that soften the light without absorbing too much of it?
Luchen
15 Oct 2023 10:14
For my Metod lighting, I used slim aluminum profiles with a frosted diffuser, which can be cut quite easily. The LEDs are well protected underneath, and the light is distributed evenly. Installation is quick since the profiles are mounted with clips. Just make sure there is enough heat dissipation to extend the lifespan of the LEDs.
nolan
15 Oct 2023 11:49
For more flexibility, I recommend smart LED systems with ZigBee or Wi-Fi, which can be controlled via an app or voice commands. Most also offer motion sensor add-ons. This way, you have many control options without extensive wiring work.
pa-wolf
15 Oct 2023 13:02
nolan schrieb:
For more flexibility, I recommend smart LED systems with ZigBee or Wi-Fi, which can be controlled via app or voice command.
These systems are great but often more expensive and more complex to set up. For simple cabinet lighting, it’s better to use basic technology.
Mar47
16 Oct 2023 07:55
pa-wolf schrieb:
For simple lighting control inside a cabinet, it’s better to use basic technology.
Thanks for the advice. I’m thinking of starting with classic 12V LED strips with motion sensors and maybe using aluminum profiles. Once I find an affordable and practical solution, I can still upgrade to smart systems. Are there any basic tips for wiring that can help keep cables hidden and tidy?
