ᐅ How to Properly Adjust Ikea Metod Cabinet Doors with Soft-Close Mechanism
Created on: 1 Dec 2020 14:23
Jubili
Jubili
1 Dec 2020 14:23
I recently installed the Ikea Metod kitchen cabinets with soft-close doors, but I’m not yet satisfied with the soft-close adjustment. Specifically, I’m looking for the best way to set the cabinet doors so that they don’t close too slowly or too quickly, and so they close smoothly and quietly even with different door sizes – especially for the larger doors, I feel like they don’t fully pull shut.
Which hinge settings are most important here? Is there a special trick to improve both the closing force and the door alignment? My previous attempts have been somewhat awkward, so I would appreciate a clear guide or tips on how to optimize the soft-close function properly.
Looking forward to your experiences and advice!
Santi
1 Dec 2020 15:05
Basically, when adjusting the Metod soft-close cabinets, focus on the following points:
- Screw for closing speed (on the soft-close damper) – this controls how fast the door closes.
- Screws for alignment (top and bottom of the hinge) – these allow you to adjust the door vertically and horizontally.
I recommend first setting the alignment correctly, then fine-tuning the damping speed so the door closes smoothly and fully.
refinar
2 Dec 2020 09:47
Hello Jubili,
I’m happy to provide you with a more detailed guide for adjusting the Ikea Metod soft-close doors to achieve a perfect result:
1. Door Alignment
- Start with the vertical adjustment (screw on the side of the hinge). This allows you to move the door up or down so it sits flush with the cabinet frame.
- Then adjust the horizontal screw (located at the front of the hinge) to set the door closer to or further away from the cabinet frame.
2. Adjusting the Soft-Close Mechanism
- On the damper itself, you will find a small screw or control that influences the closing speed. Turn this carefully to slow down or speed up the door closing.
3. Check the Door
- After each adjustment, open and close the door several times to test the behavior.
- The goal is a smooth and complete close without loud noises or slamming.
Important:
- Larger doors often require more fine-tuning of the damping.
- If the door sticks or doesn’t close properly, the alignment is usually off.
Summary:
- Step 1: Align the door
- Step 2: Adjust the soft-close damping
- Step 3: Test the door’s function
If you experience specific issues, feel free to describe them here. I’ll be happy to help.
rickey
2 Dec 2020 20:16
refinar schrieb:
Important:
- Larger doors often require some additional adjustment of the soft-close mechanism.
I can definitely confirm that. With my kitchen's Metod doors, I also had trouble with the large doors—they just slammed too hard. Adjusting the soft-close setting to a stronger damping helped, even though it made opening the doors a bit more difficult. At first, I was a bit frustrated because it didn’t work perfectly right away. So I completely understand that you’re still having some difficulties.
If you want, you can share how your doors are behaving exactly, and maybe together we can find the optimal setting. It really takes some patience.
Liduta
3 Dec 2020 10:02
I would like to add the following points that are often overlooked when adjusting the soft-close cabinet doors of Ikea Metod:
- Make sure to check whether the hinges are properly seated. Sometimes the doors are mounted, but the hinge is not perfectly aligned in the hinge cup, which affects the closing behavior.
- Lift the door off the hinge once and rehang it precisely; this often helps significantly.
- Another important aspect is the cleanliness of the joints – dust or small particles can interfere with the soft-close function.
- When adjusting the damping, make only small increments; a quarter turn (1/4 turn) is usually sufficient. Then perform another closing test.
In summary:
- Remove and rehang the door
- Check the hinge position
- Carefully adjust the damping
- Test the function
This approach is especially worthwhile when dealing with multiple cabinets to ensure that all doors close uniformly and quietly.
