ᐅ Optimal House Orientation for a North-Facing Lot
Created on: 25 Jan 2020 22:28
Nagrie123
Nagrie123
25 Jan 2020 22:28
I need some help deciding the best way to position our house. The plot size is 498 square meters (5358 square feet). The house should be around 150 to 160 square meters (1615 to 1722 square feet). We have only roughly drawn it on the plan; the foundation slab dimensions are not fixed yet. The garage can be built right on the boundary line, but otherwise a setback of three meters (10 feet) from the property lines must be observed. We have now sketched two ideas. Could you tell me which option you prefer? If you have any other suggestions, I’m open to those as well. Our plot is the last one on the street opposite No. 14. Thanks in advance and best regards, Nadine
Floor plan: house with terrace, path to terrace, detached garage on the right; orientation N/E/S/W.
Hand-drawn floor plan sketch: large house with terrace, orientation N/S/E/W.
Nadine
Site plan of a district with buildings, streets, and parcels.
nordbayer
26 Jan 2020 12:40
I find the first option more appealing because of the afternoon sun. I think the narrow terrace strip on the west side can be omitted; I would prefer a slightly larger terrace on the south side instead. It is also essential to ensure there are options for shading.
Georgie
26 Jan 2020 15:04
I also prefer the first option with the southwest-facing terrace, but the detached garage placed so far back? That means paving almost 20 meters (65 feet) of driveway.
Nagrie123
26 Jan 2020 16:14
Thank you both for your responses!
Georgie schrieb:
I also prefer the first option with the southwest terrace, but the detached garage that far back? That means almost 20m (65 feet) of driveway to pave.
Yes, I know it’s a bit inconvenient, but we don’t know how to change it. The garage is directly on the property line, and the house is attached right next to it. The front door was planned on the right side. So if we move the garage forward, we don’t know where the front door would go.
kaho67426 Jan 2020 17:48
Placing the garage directly in the corner often exceeds the maximum allowed setback. Commonly, this is 9m (30 feet). With 7m (23 feet) plus 4.5m (15 feet), you’d already be at 11.5m (38 feet). Is that permitted in your area?
Pinky030126 Jan 2020 17:56
How do you access the front door in the second option?
