ᐅ Opinions on the Floor Plan – Duplex Bungalow for Rental Purposes
Created on: 25 Oct 2021 20:49
Tx-25
Hello, I have created the floor plan for a duplex bungalow with two rental units. There is a utility room planned with one heating system for both apartments.
Development Plan/Restrictions
Plot size: 700 - 900 sqm (7,535 - 9,688 sq ft)
Slope: No
Floor area ratio (FAR): 0.4
Site occupancy index: 1
Number of parking spaces: 1 on the left, 1 on the right
Number of floors: 1
Roof shape:
Orientation: not yet fixed
Maximum height/limits:
Additional requirements: 4.50 m (15 ft) maximum eaves height
Who designed it:
- Do-it-Yourself
What do you like especially? Why?
No wasted space, hallway as small as possible without feeling cramped.
What don’t you like? Why? Bedrooms and study too small?
My cost estimate:
€350,000 including 2 carports and the plot (€40,000)
Preferred heating system: air-to-water heat pump
If you had to give up, which details or features could you do without?
- Could give up: carport, instead of a hip roof a flat roof (6 percent slope)
Why is the design the way it is? For example:
In our new residential area (we moved into our single-family house last year), someone built something similar. Their apartments each have 99 sqm (1,065 sq ft). I optimized a bit and reduced the hallway size. Otherwise, much is adopted.
I think it’s good that there is only one utility room. Also, the distances are short (for pipes and walking paths).
Slope: No
Number of floors: 1
Roof shape:
Who designed it:
- Do-it-Yourself
My cost estimate:
Unfortunately, I cannot provide specific information about the plot yet. In fact, a new residential area is being planned in our community. The plots there are expected to have similar shapes to those in our current development. The plot sizes range between 700 and 950 square meters (7,535 and 10,225 square feet). I was one of the first to inquire and can therefore choose from the available plots. However, I have not yet received any plans.
So why am I already looking at floor plans? Because I want to base my calculations on them. Maybe I will even conclude that renting out the property isn’t worthwhile, for example, if the costs for a semi-detached bungalow are disproportionate. But I can only make accurate calculations with a floor plan.
Since I have a wide selection of plots, I believe the house will fit well and can be properly oriented. For pricing, I have initially assumed a larger plot.
Tx-25 schrieb:
In fact, our municipality is currently opening a new residential development. The lots there are expected to be similar in shape to those in our existing development. The lot sizes will range between 700 and 950 square meters (7,535 to 10,225 square feet). I was one of the first to inquire and therefore have a choice of lots. However, I have not yet received a site plan. If I were to get lots ranging from 700 to 950 square meters (7,535 to 10,225 square feet) after a land consolidation process plus public areas, I would, based on today’s market situation, divide two or three new lots out of one — and with semi-detached or duplex houses on 950 square meters (10,225 square feet), even four. It’s no different for plots owned by the municipality: local councils generally prefer to satisfy more families with smaller lots rather than develop large luxury lots. The development objectives were likely already discussed in council meetings and later published in the local newsletter. So you should at least be able to provide rough key figures about the building mix and the floor area ratio / plot ratio here.
Tx-25 schrieb:
But I can only calculate this with a floor plan. Honestly? That is one of the last things an investor needs upfront. By the way, duplex bungalows are among the least marketable house types. And if they are built, the first occupants usually want to have a say.
Tx-25 schrieb:
Because I have a large selection of lots, I believe the house will fit and I can orient it well. All the more reason not to arrange your rooms with general orientations like front/back/side, but specifically by the cardinal directions north/south/east/west.
Smialbuddler27 Oct 2021 18:28The shared wall between both halves is located exactly where the sofa—or seating area—is imagined, and it also looks alarmingly thin. Is this just due to the drawing, and is it actually planned to be fully separated like a semi-detached house, or is it really intended this way? What type of material is it planned to be made of?
Smialbuddler schrieb:
The shared wall between the two halves is located exactly where the planned sofa or seating area would be and also appears alarmingly thin. Is this just a result of the drawing, and is it actually intended to be fully separated like a semi-detached house, or is it really planned this way? What type of material is it planned to be made of? This is neither a manufacturing drawing nor a professional design: it is a sketch intended to capture ideas, not for building permit / planning permission purposes.
If I could get back 700 to 950 sqm (7,535 to 10,225 sq ft) of my properties plus communal areas from a land consolidation process, I would currently divide two to three new lots out of one — and with single or semi-detached houses, even four on a 950 sqm (10,225 sq ft) plot. The situation is similar on land owned by the municipality: councilors prefer to make more families happy with smaller plots rather than developing large luxury lots. The development goals were probably already mentioned in council meetings and later published in the local newsletter. So you should at least be able to refer to rough key figures about the building mix and the floor area ratio/site occupancy index here. Currently, two types of lots are being sold here. One type consists of very small plots near the village center, and the other type consists of larger plots ranging from 700 to 950 sqm (7,535 to 10,225 sq ft) for families with children. These larger plots are located on the outskirts and cost about half per sqm compared to the smaller ones.
According to the municipality, the property data will be as follows:
Site occupancy index (floor space index): 0.3
- Floor area ratio (FAR): 0.3
- Number of full floors: 1
- Detached single-family houses or single- and semi-detached houses allowed
- Open building layout permitted
