ᐅ Electrician's Quote – Is the Price Justified?
Created on: 5 Apr 2013 15:56
Daniel87
Daniel87
5 Apr 2013 15:56
I received the quote from my preferred electrician, and I find it quite expensive. Here is an excerpt:
1 single-pole switch for an outdoor light point: €52.00
1 standard socket outlet supply and installation: €48.00
1 two-way switch for a light point: €52.00
1 Merten room thermostat supply and installation: €89.00
1 meter cabinet including all circuit breakers supply and installation: €1,450.00
1 empty conduit box with cables for telephone or antenna: €45.00
1 satellite system Astrosat Hotbird and Astra, 9 inputs, 8 outputs: €550.00
1 video intercom system including 2 video stations: €1,044.00
Roller shutter control for 23 windows: €1,485.00
6 step lights supply and installation: €534.00
All prices are net (plus VAT), including installation, chasing, etc. The switch range is apparently standard white from Merten. The total amount is €11,169.00 net, which equals €13,291.11 gross. This seems quite high to me, especially since not all the sockets I need are even included. However, he provides the temporary construction power box free of charge.
The house measures 12 x 12 meters (39 x 39 feet) with no basement.
What do you think? Are these prices reasonable, or should I push him harder?
Daniel
Der Da5 Apr 2013 17:06
What exactly don’t you like about it? I actually find some of the prices quite low. But I only know the additional costs that our home construction company charges.
5 Apr 2013 17:14
So, according to the service specification, we will pay 39.50 (incl.) for a simple outlet (also standard Merten). Your preferred electrician charges almost 25% more?!!!
Since we are not there yet (maybe in 2-3 months), I cannot say anything about the other costs. But wow, I find that quite steep. I usually calculate with less, but I can at least roughly include your figures for the two-way switch and other items. Thanks.
carthamen
7 Apr 2013 23:06
Your electrician’s calculations seem quite unusual. My quotes for a Schuko socket – fully installed GIRA 55 – range from 19,-- to 39,-- euros, a single-pole switch with a ceiling light fully installed from 26,-- to 41,-- euros, and a two-way switch from 45,-- to 53,-- euros. I consider the other prices reasonable. For telephone/antenna connections, even 45,-- euros is a good price (my quotes range from 47,-- to 95,-- euros).
For the electrical distribution board, the price ultimately depends on how many RCDs (residual current devices) you have and whether an additional meter is needed, for example, for a heat pump. Only then can the price be estimated. Regarding the roller shutter control for 23 windows, it depends on how many individual controls there are and whether a central control has been installed.
Bauexperte
8 Apr 2013 10:24
carthamen schrieb:
Your electrician calculated that quite strangely...
He didn’t, and besides, you can’t compare your prices with his. You are from NRW, the person asking is from Saarland – there are usually huge differences between these regions!
Regards, Bauexperte
carthamen
8 Apr 2013 11:16
Bauexperte schrieb:
He hasn’t, and you can’t compare your prices with his. You are from NRW, the questioner is from Saarland – there are usually worlds of difference between the two regions!
Best regards, Bauexperte
.....................is it really that much more expensive in Saarland? I always thought that many things were cheaper there – including construction costs.
